$ replacing u joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a.s., Jun 24, 2019.
  1. Jun 24, 2019 at 1:51 PM
    a.s.
    a.s. [OP] Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Taking her into the stealership this week for a nasty vibration that’s been steadily getting worse. Before I get hosed can I get an idea at what replacing the u joints (should) cost me? Any insight and advice is greatly appreciated.
    Thank you.
  2. Jun 24, 2019 at 1:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Dealership wont replace ujoints, they will want to replace the whole driveshaft at a part cost of ~1100 bucks.
    You can replace the u joints yourself for ~ 30 bucks a piece, and while you are there replace the CB.
  3. Jun 24, 2019 at 1:58 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    i can tell you the ujoints at my price are 59$ a piece, i imagine its somewhere around 75 ish for normal customers. They are 30 bucks a piece off Amazon and all the same part number. Then just pay labor.
    bax and a.s.[OP] like this.
  4. Jun 24, 2019 at 1:59 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    what wack ass dealership doesnt do ujoints? they take like 3 minutes each once the shafts out!
    bax, Gunshot-6A and Blue92 like this.
  5. Jun 24, 2019 at 4:10 PM
    nd4spdbh
    SoCal
  6. Jun 24, 2019 at 5:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The dealership in Flagstaff AZ replaced mine 3 years ago. We were visiting the Grand Canyon. On the last leg of our trip I felt a vibration all day. By the time we pulled into the campground it was squeaking. On a Sunday afternoon. I left my wife to see the sights and drove back to Flagstaff and was there when they opened on Monday. Cost me just under $300 for one U-Joint. I could have had my normal local mechanic do all of them for less. But when you're 1700 miles from home and don't have anyone to trust I paid the ransom. I might have gotten screwed over even worse at an independent shop in that situation.
  7. Jun 24, 2019 at 7:14 PM
    nd4spdbh
    SoCal
    try to order the part and have the dealership replace it. There was literally a TSB regarding U joint failures wherin the WHOLE shaft gets replaced.
    OP seriously. Just do it yourself or have an independent trusted shop do it, to replace the 3 u joints and carrier bearing its maybe 2 hours of labor. So 120 bucks per hour permium labor + 50 bucks a joint due to markup + 50 ish for a cb you are looking at 450ish OTD.... when you could do it yourself for about a third of that.
    Gunshot-6A likes this.
  8. Jun 24, 2019 at 7:35 PM
    a.s.
    Stack
    NY
    Very helpful. Unfortunately I do not have the time or desire to do this myself so I’ll have to pay the man. Just looking to arm myself with good intel so I go in prepared. Thank you.
    bax and cgs2k2 like this.
  9. Jun 24, 2019 at 7:40 PM
    TacoTuesday1
    FL
    might be a dumb question, but is it ok to use a cheap aftermarket CB?
    Such as from Amazon or RockAuto; they appear to be around $15-30
    I wonder why U-joints wear out. Is it neglect from lack of greasing? Do they even have grease/zerk fittings on them?
    In which case, maybe after installing new ones, it can help prolong their life by adding 'greasing' to the maintenance schedule?
    Last time I did something like that was on street car sway bar bushings. For an aftermarket Hotchkis bar kit. The brackets came with zerk fittings so I bought Hotchkis's white clear bushing grease (big tube) and a pistol-grip grease gun on sale from NAPA for like $20, thinking I'd grease them every 5k mile oil change.
    But even that may have been too frequent because when I did, the old grease getting pushed out still looked good, and there were no symptoms to treat such as squeaking.
  10. Jun 24, 2019 at 7:49 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Stealership told me that there was a tsb until November but they couldn’t do mine because they can prove that the vibration comes from the U joints because my truck was “ heavily modified “ those were the words that they used. That was the most retarded answer that I ever got from them.
    NEUMATIC and TireFire like this.
  11. Jun 24, 2019 at 8:16 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    This is what i ran into. The dealership wanted to replace the driveshaft for $2500 i i had a local shop replace the u joints Then toyota had a recall and i was able to get reimbursed for the cost of the repair.
  12. Jun 24, 2019 at 8:26 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Regarding the TSB if you have a lift or bigger tires Toyota won’t pay, most likely. In that scenario it’s better to have an independent shop do it and try to get reimbursed so that Toyota won’t find out about the mods or they’ll most likely deny.
    Or as @nd4spdbh posted just get the ujoints from Amazon and do yourself. I carry one in my truck as trail spare anyway.
  13. Jun 24, 2019 at 9:14 PM
    daveycrockett
    daveycrockett New Member
    2005 tacoma Prerunner v6 6 speed stick
    I bought a 12 year old 2005 Tacoma Prerunner with 147,000 miles on it. It had a whole truck vibration to it. I took it to a drive shaft specialist, after having new front shocks and alignment done. The shocks were original and never replaced. They replaced the 3 u-joints and the carrier bearing. This took care of the vibration. The carrier bearing was an O.E.M. Toyota part. The shafts were balanced. Cost for all bearings was $438.00. The good news was that the dealer I bought it from paid both bills. The shocks and the drive shaft bill. I had a 90 day warranty on this truck.
    PzTank likes this.
  14. Jun 25, 2019 at 6:13 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I paid $180 earlier this year for mine. Parts and labor.
    I highly recommend not bothering at all with the dealership. Just go to an independent shop. This is an easy job.
  15. Jun 25, 2019 at 6:17 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I did mine myself with a little harbor freight shop press and some impact sockets lol cost me like $50 and about an hour and a half.
  16. Jun 25, 2019 at 7:12 AM
    a.s.
    Stack
    NY
    November 2019? Or this past November?
  17. Jun 25, 2019 at 8:09 AM
    nd4spdbh
    SoCal
    I run an IEDLS Poly Ford Ranger CB, but i can because im a 4x4 and have a slip joint after the CB. If OP is a prerunner hes gotta use an OE style doughnut CB to allow the driveshaft to move forward and back through the CB. Not sure how the aftermarket CB's are for prerunners however.
    As far as U joints, yup, lack of greasing / ingress of nasty shit / general wear. Most prerunners came with Non greaseable joints that were marginally greased from the factory... I want to say all 4x4's came with the same joint i linked to above (a greaseable one). Prerunners can use the same greaseable joints as the 4x4's. I grease mine with every oil change 8-10pumps of grease, yeah it might be excessive, but for the 30cents of grease per joint, its well worth it and will GREATLY extend the life of the joint.
  18. Jun 25, 2019 at 8:11 AM
    TacomaSport86
    Yes id also recommend replacing the ujoints with greasable ones.
    jetfishn likes this.
  19. Jun 25, 2019 at 8:16 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ask your local Fire Chief where he gets his work done
    a.s.[OP] likes this.
  20. Jun 25, 2019 at 8:22 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    prepared for what? If you aren't willing to do the work yourself, then you are prepared to get raped only. I suggest lube.
    ABNFDC and op9nf like this.
