Replacing Water Pump and Rebuilding Head - QUESTIONS!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmogSUX, Jul 19, 2016.
  1. Jul 19, 2016 at 1:13 PM
    SmogSUX
    SmogSUX [OP] No Money. No Love.
    Sacramento
    96 Tacoma Manual 2.7L 4x4
    Wheelers 5-Pack w/ AAL, ToyTec 1" Shackles, 10" 5125's, 5100's w/ ToyTech Springs, Braided Steel Brake Lines, AFE Filter, BAMF Sliders
    I'm having the head rebuilt on my Tacoma soon, so I was going to do the water pump, thermostat, and front main seal (FMS is seeping a small amount). The truck is a 1996 4x4 with a 2.7L 3RZ with 220K.
    My questions are this:
    Should I buy all of the gaskets needed separately through Toyota or should I buy a full kit from Ebay/Amazon? (I'm buying OEM head gasket and OEM head bolts)
    Should I buy the OEM water pump or are the off brands good? (I'm buying OEM thermostat)
    I saw that OEM is around $125, whereas I can get AISIN for $46 (Isn't OEM AISIN brand?)
    Does the machine shop usually adjust the valves for me when they rebuild the head? The whole reason I have to have it rebuilt is because I burnt an exhaust valve (220k and they were never adjusted) on 1, maybe 2 cylinders. I tested and got 175-75-150-170 compression, added oil to the lower compression cylinders and they didn't go up.
    Are there any other items I should address while I pull the head? The goal is to pull the head on a weekend, drop it off at the machine shop on a Monday and hope they finish it by Friday so I can reinstall the head the following weekend.
    I've replaced the head gasket on a few vehicles without an issue (always dropped the head off for machining), so I don't think I will run into any real issues.
  2. Jul 19, 2016 at 1:17 PM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    How do you know that the headgasket isn't the cause of your low compression?
  3. Jul 19, 2016 at 1:38 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    If it is a quality brand like Fel-Pro, Victor-Renz......by the kit.
    Yes AISIN is the OEM brand. Just make sure the stock one and the new one are the same animal.
    Once your get the head off, Have a valve seat job done on the head and have them resurface the valves.
    You adjust the valves on when the head is back on the engine.
    Have the shop check the head to see if is warped. Or you can do it with a straight edge.
  4. Jul 19, 2016 at 1:40 PM
    CD20H
    Ben
    North Texas
  5. Jul 19, 2016 at 2:54 PM
    SmogSUX
    Sacramento
    I figured that the valves have never been adjusted for the life of the truck (Or at least the last 150k miles) and it's a common issue with the 3RZ. Also I haven't added coolant to the truck in over a year, there's no coolant in my oil or vice versa, no overheating issues, no coolant system pressure issues, etc.
    Thanks! I'm pretty bummed about having to adjust the valves...sounds like a royal pain in the ass.
  6. Jul 20, 2016 at 1:27 PM
    SmogSUX
    Sacramento
    What do you think about this kit:
    http://www.rockauto.com/en/moreinfo.php?pk=1949182&cc=1278929&jsn=407
    Then, as I said, buy OEM head gasket and OEM head bolts?
  7. Jul 20, 2016 at 1:32 PM
    CD20H
    Ben
    North Texas
    As long as the head gasket is a MLS Multi-layered-Steel you will be ok.
    I would look at ARP bolts if they make them. If not available, then yeah go with OEM.
