Replacing Weld Nut - TRD Pro Skid Plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by th3clara, Feb 27, 2023.
  1. Feb 27, 2023 at 9:00 AM
    th3clara
    th3clara [OP] Well-Known Member
    Trevor
    Portland, OR
    2020 TRD Pro - Army Green
    RIDE Shocks 255/85r16
    The rear two bolts for the TRD Pro skid plate are held in by nuts that are welded to the inside of a crossmember. These nuts can break off from overtightening using an impact/air tool, or from rust. The skid plate doesn't need to be removed for an oil change, but does need to be removed for a front diff service, when this happens you run the risk of a technician overtightening and breaking these nuts (I think that is what happened to me).
    Once the weld breaks, its pretty much impossible to properly torque your skid plate due to the location of the nut being inside a cross member. The nut is also square, and doesn't properly fit in any metric or standard socket wrench (I found that 9/16 is the only socket that gets any grip on the nut).
    Aside from the tightening issue, once rust starts to build up on the nut, it becomes very difficult to remove the nut. I wanted to install a steel front skid plate, but have been fighting this nut for awhile now. Below is the solution I came up with.
    Photo of the broken welds on the nut (passenger side only).
    I could get my fingers in the cross member, but rust prevented me from loosening the nut by hand. A socket wrench with angle adapter was the only way I could get a socket over the nut, however the awkward size/shape of the nut caused the 9/16 socket to keep slipping (13mm & 14mm don't fit on the nut).
    I ended up spraying the nut using magnetic penetrating lubricant and let it sit overnight. Tried the socket again and was able to get it loose, then removed it by hand.
    Rather than reinstall the weld nut, or swap it out for a flange nut, I needed something that would allow me to tighten the bolt without needing a wrench on the other side. I cut some 3/8" metal into 5" long sections, and then tapped treads into them. The idea is that the metal would rotate against the inside wall of the cross member and self tighten from there. When needing to loosen and remove the bolt, this metal bar would hit the opposite side wall of the cross member and hold itself while undoing the bolt.
    Install of this new hardware went really well. There are enough threads in this metal to get a good torque on the bolt. The hardware is skinny enough to be able to maneuver around inside the cross member while still having enough room on either side for your fingers.
    I am unsure of what to do with the driver side, as it is not broken yet. I figure it will break eventually, and it might be better to break it on purpose and remove before rust builds up on the nut. I made two of these tapped metal bars, so that I could move ahead replacing the driver side when ready.
    Here is a photo of the non-broken weld nut on the driver side.
  2. Feb 27, 2023 at 9:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! I might have missed it, but did you go with a larger diameter bolt? That would be something handy also.
  3. Feb 27, 2023 at 9:08 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
  4. Feb 27, 2023 at 9:22 AM
    th3clara
    Trevor
    Portland, OR
    I kept the same bolt. I could possibly go one size larger, but any more than that and I would have to modify the RCI transmission skid/engine skid holes, and possibly enlarge the hole on the cross member. Upgrading the bolt didn't seem necessary since the engine skid bolts on with 6 bolts.
    tonered[QUOTED] likes this.
  5. Feb 27, 2023 at 9:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff. It was more about just using a single 17mm to drop it.
    I do take mine off for oil changes having cleaned up messes from other skids that had oil change access. Just works better for me with it gone.
  6. Feb 27, 2023 at 9:50 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Put anti-seize on all those bolts. Also put a little on the 4 countersunk allen bolts that hold the oil filter access panel in place.
    th3clara[OP] likes this.
  7. Feb 27, 2023 at 10:16 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Next time just use a SS Rivnut.
    Chuck X1, AvalonTaco and BillF1564 like this.
  8. Feb 27, 2023 at 10:39 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I think so, yes.
    Honestly not the worst idea. My issue right now as Mr. Floats knows is the damn thing ain't coming out. So, that's good to see someone else and how they approached it. I'm good with just a SS flange nut though.
  9. May 13, 2024 at 12:39 PM
    Hpen123
    Hpen123 Active Member
    Harry Pence
    21' TRD OR Tacoma
    Wheels/ 275/70 R 17 AT's, OME Suspension, CBI front bumper, RCI Skids/sliders, prinsu rack.
    Thank you for this thread, glad to know I am not the only one that did this! Also seemed weird no socket seemed to work on that top nut.
  10. May 13, 2024 at 12:46 PM
    GarlicFarts
    Lil Rhody
    Oh an update.
    Tried to reach up in there with a wrench of some sort. We might have had some success? But we ended up just needing to sawzall the bolt off. Got all over 5 bolts out, let the skid hang down a bit, and got a sawzall blade between the skid and cross memeber, and cut it out.
    Replaced with rivnut.
    AllTacosFloat and Hpen123 like this.
  11. May 13, 2024 at 12:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    An 8 point socket should fit the square nut.
    GarlicFarts likes this.
  12. May 13, 2024 at 1:08 PM
    Hpen123
    Harry Pence
    21' TRD OR Tacoma
    Cutting it was my plan after some time fighting with it.
  13. May 13, 2024 at 1:09 PM
    Hpen123
    Harry Pence
    21' TRD OR Tacoma
    I think it is an odd size as well.
  14. May 13, 2024 at 8:55 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I've been faced with situations like this a few times myself. What I've found works best is to weld a hex nut to the piece of metal. My experience has been that threads tapped into mild steel tend to strip out easier than if using a nut.
    Additionally, if you drill a couple holes to either side of where the bolt goes through the frame or crossmember, you can then weld the metal piece w/nut into place by welding through the drilled holes (plug-welding it) so it's not moving around in there every time you disassemble it.
  15. May 15, 2024 at 4:51 PM
    Chuck X1
    Chuck X1 Well-Known Member
    Chuck
    NW Indiana
    2020 Tacoma TRD Off Road
    Get a riv-nut gun from Harbor Freight. My wife’s 4-runner skid plate had about 8 stripped nuts and the dealer quoted $600 to fix. Harbor Freight for the win!
    auskip07, jmneill, soundman98 and 3 others like this.
  16. Sep 16, 2024 at 7:38 AM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Thank you for posting this. After trying to get a wrench on that nut for an hour I finally looked it up to see wtf was going on. Stupid design!
    Cut it off and replaced it with an M8 rivnut (did have to drill out the hole just a little). The rivnut works for me but it’s maybe not ideal because the cross member is slightly curved there, so it sits at a slight angle. My skid pan has plenty of room in the slot to accommodate that though so it’s just fine. And you’d better believe that now I have anti seize on all the bolts too. :D
    Roof Walker and GarlicFarts like this.
  17. Sep 16, 2024 at 8:25 AM
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
    When my weld nuts broke loose I just ended up cutting the hardware off because they were rusted and seized up on me. The easiest solution I came up with was using a spare nut I had and holding it in place through the side opening of the crossmember and tightening everything down with a flex head ratchet. That was about 6 months ago and everything has held up so far.
  18. Sep 16, 2024 at 11:33 AM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Yeah, the idea of fucking around with that every time I needed to drop the pan sounded annoying, so I went with the Rivnut option.
    Stuck in VT and GarlicFarts like this.
  19. Sep 16, 2024 at 11:41 AM
    GarlicFarts
    Lil Rhody
    +1 I drop my skid every year for undercoating. So it's not really one I can set it and forget it.
    But if you can get a wrench in there relatively easily, it's not that bad. Magnets on a stick would help a lot too.
  20. Sep 16, 2024 at 12:04 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I've been wondering if rivnuts are strong enough long-term? Obviously the skid plate isn't going to fall out, but will have the same problem in a few years? If the old nut failed due to corrosion/over-tightening, aren't rivnuts a lot weaker? Do you just keep the hardware coated in anti seize?
