Replacing your water pump/impeller for your boat
Discussion in 'Boating & Fishing' started by genxer36, Jul 8, 2009.
  1. Jul 8, 2009 at 1:12 AM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I replaced mine a couple of years ago without any idea how to do it(below are links on step by step instructions). It took me about 2 hours & was easy. When they say water pump, really all you are replacing is the impeller (& replace the seals if needed). The impeller on the left is bad. The one on the right is how it should look.
    I will replace mine at the end of the summer. It is good to replace it every few years or so. I figured since we talk about repairing our trucks. We needed this write up for our boats also. You can save hundreds of $$$ doing it yourself. I think it cost me about $20-$30 for an impeller last time.
    Mercury:
    http://www.bassboatcentral.com/sttips.htm
    Evinrude & Johnson:
    http://www.bassboatcentral.com/johnrudetips.htm
    Mercury Video:
    http://www.youtube.com/watch?v=E-uzQi7IgwU
  2. Jul 8, 2009 at 6:34 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    stuckified. Thanks Sean.
  3. Jul 8, 2009 at 6:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Awsome info!!!
  4. Jul 8, 2009 at 3:39 PM
    genxer36
    Sean
    Bethlehem,GA
    It is easy to do, even for a noob.
  5. Jul 8, 2009 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO! I need to do this to mine. :eek:
  6. Sep 3, 2009 at 6:26 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    ill probably order one for my motor this winter seeing as the last time i did it, was well over 4 years ago, and the boat has sat winterized for 3 years
  7. Sep 6, 2009 at 4:58 PM
    genxer36
    Sean
    Bethlehem,GA
    Probably wouldn't hurt. I plan on changing mine after fall fishing.
  8. Dec 26, 2009 at 12:12 AM
    DionysiosA76
    DionysiosA76 Captain Analyzer
    Dionysios
    Barrington, IL
    07 Taco Sport DC 6 spd-SOLD FOR CUMMINS
    Totally custom straight pipe exhaust sourced from an 01 Cummins (fabbed up by yours truly), ScanGaugeII, Westin Bull Bars, air horns, Truxedo tunneau, Black decals, Black rotors, black calipers, Secondary Air filter removal, reengineered dirtbike hauler, auxillary back up lights, blacked out tail lights, socked by Sockmonkey, blacked out hi-stop, TRD stickers (+300hp :) Owens Running Boards, Greek flag shifter, Garmin Nuvi 755w GPS, Cobra 25ltd CB with a 4' fiberglass whip... and never paid anyone nuttin to do it.
    We have twin 2stroke 8v71TA Detroit Diesel's (VERY dirty, noisy, but simple as hell engines) in our 37' Mainship that are equipped with Sherwood water pumps that on average require replacement every 10-15 running hours. Needless to say we have the sherwood guy on our speed dial :D
  9. Dec 26, 2009 at 4:35 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    I do mine every 2-3 years and replace the t-stat and pop off valve at the same time. The parts aren't that expensive, it is pretty easy to do and I don't want to have to come home on trolling motor or worse, paddle!
  10. Mar 29, 2010 at 4:42 PM
    genxer36
    Sean
    Bethlehem,GA
    What is the t-stat & pop off valve? Pics would help. Thanks
  11. Mar 29, 2010 at 5:05 PM
    Taco John
    Illinois
    4X4
    Thermostat and pop off (poppet). On my merc, they are in the engine block under a cast cap with a few bolts. Much like replacing the t-stat in a car but easier to get to :)
    Tbe attachment is a snap from the merc parts page - the poppet is 39, the t-stat 44, etc. i replace 38- 47 with the exception of 45 and 46. Not that expensive and after 8 years in the hard water around here, worth the piece of mind.
  12. Mar 29, 2010 at 5:50 PM
    genxer36
    Sean
    Bethlehem,GA
    That looks a little beyond my capabilities. I have a 1991 175 Mercury. I can do some things. But when comes to inside the engine I'm gun shy.
  13. Mar 29, 2010 at 5:51 PM
    genxer36
    Sean
    Bethlehem,GA
    Wow! 10-15hours? That would get expensive.
  14. Mar 29, 2010 at 5:57 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Done it a few times on my Johnson 30...not a bad job when the motor was newer, now its hard to get the lower unit off without issues. I got a good shop buy me to take care of that motor.
  15. Mar 29, 2010 at 6:54 PM
    genxer36
    Sean
    Bethlehem,GA
    I have a Bass Pro near me. Their service dept is top notch! I have had repairs done where they quoted me one price, but when the work was completed they have always come in way under the quoted price.
  16. Jun 12, 2014 at 5:46 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Around here the BPS boat department is a joke. I wouldn't trust them to change a prop.
  17. Oct 4, 2023 at 5:36 PM
    Kapnd
    Kapnd Active Member
    There is something fishy going on with your pumps, that is a ridiculously short service interval.
    The pump cavity, end plates, or cam may be deteriorated, causing premature impeller wear.
