Reprogramming remote control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harleyg, Nov 10, 2011.
  1. Nov 10, 2011 at 1:33 PM
    harleyg
    harleyg [OP] Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    Is there a way to reprogram the wireless remote control key so it does not beep when locking and unlocking my 2011 Tacoma? I did a search and only found programming a new key to the truck.
  2. Nov 10, 2011 at 2:55 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Yeup
    you mean the fob
    open driver door
    insert key into ign
    remove from ign
    within 5 seconds reinsert key and turn ign switch on
    after 10 seconds MAY give you an answer back buzzer
    within 10 seconds after that hit a transmitter button twice to change the setting.
    I did not get an answer back after 10 seconds but it does work.
  3. Nov 10, 2011 at 3:04 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    WRONG AGAIN
    The beep is canceled out with this procedure No box has to be removed.
    He said BEEP NOT HONK !!!!!!!!!
    Look at my truck on the left. Look at the year. Look under for my mods and it specifically says
    Disable fob beep !!!!!!!!!!!!!!!!!!!!!!!
  4. Nov 10, 2011 at 3:07 PM
    harleyg
    Harley
    No honk, just the beep. Sounds like the programming steps only work with the honk?
  5. Nov 10, 2011 at 3:10 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    THE BEEP Is what i gave you the procedure for
  6. Nov 10, 2011 at 4:01 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Wait, i thought whipper was NEVER wrong?!?!?! How could this be? Is anything real anymore? Guess thats life, all those posts and yet still doesnt know everything. WOW real shocker! NOT!
  7. Nov 10, 2011 at 4:11 PM
    Toyota Tech31
    Debary, Florida
    what exactly does that have to do with reprogramming a new remote? Silly whipper, find someone else to blame, unless you care to bring it to my shop and see exactly what a real tech can do, not just troll the forum all the time like yourself. Thanks!
    Fact is i have never and would never claim to know everything, the great thing about my job is always learning, and if i dont know, i take the time to find out the facts!
  8. Nov 10, 2011 at 4:12 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You two figure out my VSC question yet ?
  9. Nov 10, 2011 at 4:15 PM
    Toyota Tech31
    Debary, Florida
    never researched that one, but like i said i have never seen anyway with our systems to adjust the threashold like you asked, but you should check with whipper, he seems to really know his shit lately.
  10. Nov 10, 2011 at 4:17 PM
    OZ-T
    Peter North
    British Columbia
    I'm asking you because you are the self proclaimed Master Tech , so if you don't know , who would ?
    So find out for me already .
  11. Nov 10, 2011 at 4:17 PM
    Toyota Tech31
    Debary, Florida
  12. Nov 10, 2011 at 4:19 PM
    Toyota Tech31
    Debary, Florida
    Probably cause you couldnt handle actually working instead of sitting on the computer all day trolling TW
  13. Nov 10, 2011 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    Excuse the interuption of your Tampon-a-thon here , but is there a way to find out about the VSC thing ?
  14. Nov 10, 2011 at 4:30 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, Clazzio seat covers, BHLM with removed turn lens, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    So I take it only 09 and after tacos are equipped with the beep? I got an 07 and it appears the previous owner disabled a lot of stuff. I don't mind some of the things he disabled like the seat belt chime, but I'd kinda like to have the beep when I lock/unlock the doors.
  15. Nov 10, 2011 at 4:31 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Sure is
    NO you can't and won't be able to change the threshold.
    It either has to come programmed from the factory in a new ecu or have a program added to our computers to flash the ecu. It would not be programmable for us you can be assured of that.
    Toyota will never allow ANYONE including field techs to be able to program by themselves a brake system or any related yaw rate sensor etc. Ain't gonna happen.
    I can imagine the can of worms that would start.
  16. Nov 10, 2011 at 4:37 PM
    OZ-T
    Peter North
    British Columbia
    Figured as much .
    Thanks
  17. Nov 10, 2011 at 4:40 PM
    Toyota Tech31
    Debary, Florida
    Wow, someone tries to stand up to this idiot whipper and this is the response i get? dont worry, when you guys need help on here you can feel free to ask whipper what he would do. I wouldnt want to take away from the spotlight you guys shine on him, my bad, i will make sure to take a step back when the all knowing whipper is involved.
  18. Nov 10, 2011 at 4:42 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Hey no problem.
    For people who can drive and do mods correctly doing what you suggest would be awesome. To be able to tweak for your setup or driving style would be sweet.
    BUTTTTTTTTTTTTTTTTT NAAAAAAAAAAAAAAAA
  19. Nov 10, 2011 at 4:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the point here is this ^^^
    Could have been said like this:
    "The box doesn't have to be removed. He said beep, not honk, so you just have to follow my procedure to have it turn off :thumbsup:"
    everyone doesnt know everything :thumbsup:
  20. Nov 10, 2011 at 4:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    :popcorn:........Oh....KNOCK IT OFF! (everyone)
