Repurpose QI Charging Switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erok81, Jun 15, 2017.
  1. Jun 15, 2017 at 9:29 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Has anyone used the qi switch and some of its wiring to power lights or something. I have an iPhone but even then that pad seems worthless. I was going to try to find a switch that fit there, but then figured why not use the switch?
    I'm sure you can utilize the power (for a relay) and the dimming feature. Then wire the relay to the battery or wherever you feel like going. Then you are only routing one wire into the cab.
    Has anyone done this and can save me the time of probing wires? Or perhaps the schematic for that area?
    Jag1075, siznarf, 9TRDTCO and 3 others like this.
  2. Jun 15, 2017 at 9:41 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Interesting question! Glad you brought this up
    I'll never use that switch for it's intended purpose. Nice one OP !
    :popcorn:
    su.b.rat, over60, 9TRDTCO and 2 others like this.
  3. Jun 15, 2017 at 10:43 PM
    erok81
    Imposter
    I found the wiring diagram for that switch. It's kind of worthless. So I'll just measure and figure it out this weekend.
    Oldman808 likes this.
  4. Jun 15, 2017 at 10:46 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    good idea, sub'd!
  5. Jun 15, 2017 at 10:57 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just charged my new S7 on it today, seems to work ok but gets kinda warm, guess you could always use the switch for other things.
    Masterofnone likes this.
  6. Jun 16, 2017 at 3:39 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    There's a great thread where a guy used the Qi switch to drive a relay which served as his reverse camera on/off modification.
    Since he never used the Qi, turning the Qi on activated the reverse camera (and turned the Qi on).
    I plan to follow that route rather than eat up a switch space with that mod.
    su.b.rat, Corneeeeelius and Clay7160 like this.
  7. Jun 16, 2017 at 7:43 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Good idea! I've had three phones now and they all suck charging on the Qi wireless pad: Note 4 with wireless charging adapter; S8+ and Note 5 both designed for wireless charging. They charge super slow maybe 1% every 10 minutes and then the pad often overheats and malfunctions with both orange and green lights blinking and a high pitched beeping noise. The phone is also hot to the touch. Has to be a better purpose for this area and switch!
  8. Jun 16, 2017 at 7:51 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Qi charging is useless to me. I have a tendency to be rough on phones (broke 3 i-phones & will NEVER own a Apple product again) and one Droid. Anyhoo, I have a beefy case on my current phones (yes, phones, work & personal) and the Qi does not charge it. Soo.... It hold my glasses, tape measure, or whatever little cubby stuff. It is good due to the rubber and stuff doe not slide around.
    smitty99 likes this.
  9. Jun 16, 2017 at 8:11 AM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    I'd like to do the back up camera mod, haven't found the mentioned thread yet
  10. Jun 16, 2017 at 8:19 AM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    I use mine all the time. Its always on. I was actually thinking about going the other way and wiring it so it is always on. Then re-purposing the switch hole for my Nav switch so my passenger has access. A schematic would be useful.
  11. Jun 16, 2017 at 3:15 PM
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    Yeah I did that. I posted about it in a thread about backup cam anytime in the 3rd gen forum, but it looks like that thread got deleted, which is super aggravating.
    What I did was for the speed sensor mod, I tapped the switched power and ground off the Qi switch and ran them into a relay so that when the Qi charger is on, the nav unit gets the speed signal, and when it's off it doesn't. That way if I want a passenger to enter an address or something I can just bump off the Qi switch and then turn it back on after.
    Here are the wires I tapped. Can't remember exactly, but I think the white one was ground and the blue was switched power. I had to remove the bezel around the radio and the climate controls, then popped out the switch and unplugged it so I could pull it out the back and get to the wires.
  12. Jun 16, 2017 at 4:05 PM
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Dude
    Thanks
    I spent every shitbreak today lookin for this.
    Monday_Rex and Colorado_Taco17 like this.
  13. Jun 16, 2017 at 4:06 PM
    Clay7160
    I knew I saw post , couldn't find it
  14. Jun 16, 2017 at 4:23 PM
    erok81
    Imposter
    Sounds about right. I found the schematic page for that finally.
    Glad it worked. I'm going to do mine this weekend.
  15. Jun 16, 2017 at 5:21 PM
    ICU1
    ICU1 Well-Known Member
    My IPhone got so hot the glass popped out of the frame.
  16. Jun 16, 2017 at 5:23 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Did you have it in a case that adapts the iPhone to Qi charging?
  17. Jun 16, 2017 at 5:24 PM
    sparkyv
    sparkyv Active Member
    Hey cheuer, it would be great to be able to see this AWESOME mod in more detail. I really want to do this, but unfortunately my electronics skills are not as strong as yours.
    Greg.Brakes.Tacos likes this.
  18. Jun 16, 2017 at 5:26 PM
    sparkyv
    erok81, can you post a link to that schematic, please?
  19. Jun 16, 2017 at 5:26 PM
    ICU1
    Yes it was. iPhones do not have Qi. I purchased the adaptor according to what the dealer said to buy. Big mistake. It phone could have caught fire it was so hot
  20. Jun 16, 2017 at 5:28 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I think heat issues are the biggest reason why Apple has stayed away from Qi charging.
    BSFord and Ch78 like this.
