Repurpose Qi Switch for behind dash usb
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BBQtaco74, Dec 29, 2019.
  1. Dec 29, 2019 at 9:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The switch and the charger pad are powered by the same accessory circuit. This is a 7.5 amp fused circuit. Then it branches off to the charger and switch at the J10 junction. The switch then sends a second switched power to the charger to turn it on. This power should be more than able to power a USB charging plug. I do agree that a relay would help provide better power and reduce the load through the switch.
  2. Dec 29, 2019 at 9:42 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The circuit is the same, and it’s enough to power the USB. But it’s not pulling a load through the switch, that was my point. If the factory doesn’t trust the switches to pull power through it, IMO neither should you. Change the relay switch to grey wire rather than green wire in my reply if want to use the same circuit, I just personally wouldn’t run the load through the switch.
    edit, just saw you added a sentence to your reply. We are saying the same thing.:thumbsup:
    Speedfreak[QUOTED] likes this.
  3. Dec 30, 2019 at 3:50 AM
    caribe makaira
    Caribbean, Puerto Rico
    Skydvrr[QUOTED] likes this.
