Request for guidance: Spec of mods to phase-in over 2-3 years:
Discussion in 'Suspension' started by muleKick, Apr 25, 2025 at 1:49 AM.
  1. Apr 25, 2025 at 1:49 AM
    muleKick
    muleKick [OP] New Member
    Friday
    2021 Offroad crew cab LB
    no mods yet
    2021 Off-Road crew-cab LB; Payload capacity: 1,395lbs; all stock.
    In order of genuinely most needed changes - what should I do - from mechanical / practical suspension + rim/tires perspective - to balance ability to offroad w/ truck camper + retain ability to tow?
    Must do in a few phases to get costs past my wife - stay within my allowance.
    Getting a slide-in camper: 1,054lb w/ water etc - will reduce to ~ 875 lbs. Fits in bed / can close tailgate.
    Towing: 3800Lb pop-up camper: use only ~ 3x/yr. But, must retain good tow capability.
    I expect to do lots of moderate offroading weekend camp trips, lite gear, 2 persons, keeping camper on.
    Video (3 Years of Tacoma Modifications for Our Four Wheel Camper - Adventure Out There) says
    Four Wheel Campers (900-1300Lbs) 'requires' Offroad LB to have:
    10-ply E-rated tires + rear airbags.
    Just moved to desert-like eastern Montana - new to offroading - clueless: I assume dry, rocky, not much mud. Likely too scared to off-road/camp in winter snow. Lite/Moderate off-roading: driving gently and slow. (e.g. maybe skip rock sliders - as I can't afford to go where I could damage my truck).
    Maybe use stock rims (16", 265/70R16) for winter/non-camping + towing,
    + get 2nd rim/tires for the offroading?
    I like looks of small rims big tires - but no clue how to spec rims + tires.
    Maybe no need for mud tires - kind of desert-like here.
    Can't bear to chop up front, back, wheelwells.
    But, I can't imaging offroading to point that approach/tail clearance matter much.
    Phase 1?
    Per video:
    1 - BF Goodrich K02s w/ ?? rim-size?
    2 - bags with ARB twin compressor mounted under hood
    (Q: Is there a twin-compressor that allows in-cab, remote tire fill?)
    Spring packs, add a leaf, front/back lift kit stuff?
    Phase 2,
    Phase 3: transmission cooler?
    Thank you greatly for guidance.
  2. Apr 25, 2025 at 7:46 AM
    eurowner
    eurowner Duke Sky
    Scoty
    At least get the K03 tires.
  3. Apr 26, 2025 at 9:59 AM
    muleKick
    Friday
    no mods yet
    Thank you eurowner.
    I am reading up on suspension - seeing that my post is too long, and that its not focused enough.
    Basically I tow, carry 900Lbs constantly whilst on offroad, or am empty.
  4. Apr 26, 2025 at 4:33 PM
    eurowner
    eurowner Duke Sky
    Scoty
