Requesting Help With Sat XM receiver
Discussion in 'Audio & Video' started by bwanamukubwa, Sep 5, 2013.
  1. Sep 5, 2013 at 11:40 AM
    bwanamukubwa
    bwanamukubwa [OP] Well-Known Member
    Tennessee
    I have the toyota satellite receiver with the cable shown which i believe is for the antenna. My 2010 TRD Sport has the factory fin on the roof. What are the other two connections in the pictures and where do i get just those cables without buying the "fit kit"? I've got the ground wire that screws into the side of the receiver too, that is not shown in the pictures. Thanks in advance.
  2. Sep 9, 2013 at 7:59 AM
    bwanamukubwa
    Tennessee
    88 views and no one has anything to say??
    bump
  3. Sep 9, 2013 at 8:45 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Portsmouth, VA
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Good luck sourcing just the cables. I'd say junk yard if you're lucky. You could always open the unit and see if the connections are labeled (slight chance) and run wires out. If not labeled you can order the schematic from pioneer's OEM division (that is who makes that) and then use that to run wires out.
    Best advice I got being a previous car audio tech.
