resale value of a truck with a new frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomeontherange, Aug 10, 2013.
does a swapped frame change the resale value?
  1. yes, the price would be increased
    17.6%
  2. yes, the price would be decreased
    28.0%
  3. no, the resale value would be the same
    45.6%
  4. I don't know / no idea / no opinion
    10.4%
  5. my cat's breath smells like cat food
    9.6%
  1. Aug 10, 2013 at 7:37 AM
    tacomeontherange
    tacomeontherange [OP] this ain't no picnic
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    this may be hard to quantify / qualify but... what's your opinion?
    how does a new frame swapped in by Toyota change the resale value of a truck?
  2. Aug 10, 2013 at 7:50 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
  3. Aug 10, 2013 at 7:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wouldn't even mention it. As lo g as it was done right and you are not having any issues, who cares? The next would probably appreciate it as much as I would.
  4. Aug 10, 2013 at 8:22 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    i would think it would go down if it was known about by the buyer...i'm pretty sure it would be reported to carfax
  5. Aug 10, 2013 at 8:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Screw carfax it's all about the real facts! Like I said as the potential buyer I would actually like that. A fresh slate. I would question who installed it though just to make sure it wasn't put in by some garage "tech."
  6. Aug 10, 2013 at 8:42 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I assume this is related to your thread about your rusted out 2005.
    In general if everything else was in good condition it would improve the value to me. How it would work on a normal car buyer is an unknown.
    It'd almost be like dropping a brand new motor and transmission into a good frame from my POV.
  7. Aug 10, 2013 at 9:22 AM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    If it is reported to Carfax then it may go down a little, in the eye of a buyer. Most buyers will wonder why a frame was replaced and will automatically think that there are other problems with the vehicle.
  8. Aug 10, 2013 at 9:23 AM
    Vmmvmmm
    Vmmvmmm Member
    Greg
    Riverton, UT
    White TRD O/R
    The value of a truck is really only what someone is willing to pay, but generally, this doesn't affect the value at all. It's simply classified as a part replacement, no impact on appraised value.
  9. Aug 10, 2013 at 12:04 PM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    um, no, actually. everything has been fine. handles nicely, no mechanical problems / issues.
    thanks to everyone for contributing to this thread.
  10. Aug 10, 2013 at 12:59 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I don't recall if you did some other maintenance work during the frame swap. I was thinking you redid suspension and some other detail items.
    Having been done by a Toyota shop should hold value if not increase from not only being new but should have later improvements.
    I would also get that thing corrosion proofed and offer it as a long term truck to own.
    If you are trading it in, I would push for a lot, though the dealer will give you salvage title crap or similar.
    I did not vote though, since honestly, it is dependent upon the buyer and yourself where you settle for on price.
    PK
  11. Aug 10, 2013 at 2:55 PM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    Yeah, control arms were done. We have full records on all the maintenance we did so we expect that it will be positive information for potential buyers.
    So you think if we're private selling it that we should have it Zeibarted before we list it?
  12. Aug 10, 2013 at 4:20 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    When I brought my 03 reg cab sr5 4x4 in for inspection last January, the check engine light was on. Upon inspection, it was determined that I needed new brakes front and rear, the rear brakes were totally rusted, the parking brake cable did not work because it rusted and snapped, the co2sensors needed to be replaced and other misc rusted items. Total cost to pass inspection was $2,500. Two years ago, they replaced my frame. The asked me if I would take $6,500 on a trade for a 13 reg cab. I did. The total cost was $16,500 for a new replacement for my 03. They said they wanted my 10 year old truck because the frame was replaced and all of the tsb's and recalls we're addressed except one which was the rusted spare tire hanger. Even though the frame was replaced, everything else was rusted. The exterior body was not showing rust yet but when you opened the hood, everything was badly rusted. The shocks and body mounts were badly rusted.
  13. Aug 11, 2013 at 2:45 PM
    blm
    blm Well-Known Member
    X2. Lots of things to screw up with a frame swap. Many items that are not regular maintenance items that are messed with.
  14. Aug 12, 2013 at 4:46 AM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    It's more truck than we need. We won't be doing regular travel which requires the capacity and power it provides any more.
    The subaru we bought while this was offline for 4 months is sufficient for our needs nowadays.
  15. Aug 12, 2013 at 4:54 AM
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    As a trade in, it wouldn't matter, you would more than likely get book value regardless of what improvements were made.
    An outright sale it is possible you may get a little more from someone looking for that particular year truck. But depending on the upper price range the buyer may look for a newer truck if it is too high.
  16. Aug 12, 2013 at 6:19 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I agree with these. I would be completely honest with a potential buyer and explain what happened and what was done to fix the problem. To me it would be like buying a truck that had the engine or transmission replaced. If a reputable shop did the work, they should have no worries especially if the shop is willing to stand behind their work.
  17. Aug 12, 2013 at 9:53 AM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    thanks all. we're not planning on obscuring the swap, we see it as benign / a benefit.
  18. Aug 12, 2013 at 12:26 PM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    Yes, they had me bring it in after 30 days to tighten bolts etc. It's riding very nicely.
    hillbilly - ha! I can't lay claim to that. I'm a transplanted Keystoner.
  19. Aug 12, 2013 at 4:09 PM
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    Actually it might suggest that that is one well used 4x4 and might scare off buyers.
    I know without documented background I would stay far away from that.
    I found out my daughter wanted to buy a Jeep CJ style and my first question was a new one or a used one. Because of the fact that it's a buyer beware type thing and you don't want to buy someone's abused vehicle
  20. Aug 12, 2013 at 4:28 PM
    ANT2013taco
    McAllen Texas
    13 TRD OR 4wd
    All CJ's are used, I'm sure you meant Wrangler.
