Resealing Access Cab side windows in my 2015 AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SHBCTacoma, Apr 4, 2022.
  1. Apr 4, 2022 at 10:59 AM
    SHBCTacoma
    SHBCTacoma [OP] Active Member
    Austin
    2015 PreRunner
    None yet
    I had to replace both of my access cab side windows thanks to someone wanting to shatter them. I replaced them myself but I can hear air from potential gaps from me not doing a super professional job apparently.
    2015 Access cab
    1) Should I try to add a thin layer of silicone around the outside edge?
    2) Take the inside access door panels off and try to attempt a better seal from the inside?
    3) Take it to an auto glass shop and see if they can reinstall/seal them? I’m not even sure if they can take them off if the windows aren’t broken.
    Just curious what y’all’s thoughts are. It wasn’t all that quiet before much less now.
  2. Apr 4, 2022 at 11:08 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    #3 is my vote.
    SHBCTacoma[OP] and Key-Rei like this.
  3. Apr 4, 2022 at 11:15 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Glass is one of those things that really should be left to the professionals. Their techniques and adhesives are pretty specialized and the last thing you want it whatever adhesive you used to give up while doing 70 down the interstate and send your side window into someone's front windshield.
    Plus you should get a warranty on the work and weather sealing.
    6 gearT444E, Jimmyh and gotoman1969 like this.
  4. Apr 4, 2022 at 11:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Number # 3 no question about it.
    6 gearT444E likes this.
  5. Apr 5, 2022 at 6:18 AM
    SHBCTacoma
    Austin
    2015 PreRunner
    None yet
    Yeah definitely regretting not just paying someone the first time. It’s not horrible but a little hissing from each and now it’s all I can hear!
