Reset ECU for Aibags needed?
Discussion in 'Technical Chat' started by Smendez31, Aug 8, 2018.
  1. Aug 8, 2018 at 12:31 PM
    Smendez31
    Smendez31 [OP] Well-Known Member
    San Diego, CA
    2003 Impulse Red Tacoma, DC, V6 4x4, TRD
    OME 3" lift kit (883 springs) Magnaflow 1125 Spidetraxx 1.25" wheel spacers
    I will buy a set of airbags with the ECU and Clockspring for my 2004 Tacoma. Do I need to reset? Or can I just plug and play? It should be good right? If it's from a kit of undeployed airbags.
  2. Aug 8, 2018 at 1:37 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Is your airbag light on now?
    If not.....
    In my experience as long as the ignition isn't turned on while anything tied to the airbags is disconnected, you shouldn't get an airbag light on the dash.
    Since you're replacing an ECU i'm guessing you'll be disconnected the battery, so you should be good(As long as everything is reconnected before you reconnect the battery and turn the ignition on).
