Resetting CEL
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Mar 7, 2016.
  1. Mar 7, 2016 at 2:59 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey Guys,
    So my truck's CEL was on and was throwing P0420, and it turned out the flange connection between the exhaust pipe and catalytic converter was split, causing there to be an exhaust leak right before the o2 sensor. I fixed the flange and and replaced the gasket yesterday and I was wondering what I need to do to reset the CEL, or when would the ECU reset itself? I havent driven much since I fixed the flange.
    Thanks,
    Tom
  2. Mar 7, 2016 at 3:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    Disconnect the neg battery cable for about 30 seconds. All gone. Along with everything else that requires battery memory, like radio settings.
    Or you can use the code reader that read the code to clear the code. Well, with most code readers. Some cheap-o's don't have that function
  3. Mar 7, 2016 at 7:49 PM
    Indy
    Indy Master of all I survey.
    Any parts house will reset it for you. Them order a bluetooth o d module off of ebay for about $5, then download torque to your phone. Free code reader in your pocket.
  4. Mar 8, 2016 at 8:47 AM
    clickws
    clickws Well-Known Member
    South Carolina
    1999 Toyota Tacoma Xtra Cab 4x4 2.7L 5-Speed All Manual
    Stock Alloys w/ 31.5x10.5x15 (Previously Black Pacers w/ BFG KM2 32xx11.5)
    Interestingly enough, my CEL turned itself off after I put new 02 sensors, new catalytic converter, and replaced the manifold. I drove it for a few days and it eventually was no more. I thought I was going to have to go to a dealership but I guess the truck realized the issue was resolved and therefore turned off the CEL.
    Any others with this experience?
  5. Mar 8, 2016 at 9:55 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    lots of times once the problem is fixed/cleared the light goes out...
  6. Mar 8, 2016 at 10:12 AM
    Tjsingle26
    Tom
    PA
    I just pulled the negative battery terminal and the problem was gone
    Speedytech7 likes this.
  7. Mar 8, 2016 at 11:24 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Pulling the EFI fuse for a few minutes will have the same effect.
    Tjsingle26[OP] likes this.
  8. Mar 8, 2016 at 11:27 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just remember when you unplug the battery or EFI fuse you lose your fuel trim settings and the truck will get shit MPG for a bit while it relearns.
  9. Mar 8, 2016 at 7:01 PM
    Tjsingle26
    Tom
    PA
    Its all good though gas is cheap down my way
