"resetting" ecu for higher octane
Discussion in 'Technical Chat' started by rex99, Mar 1, 2010.
  1. Mar 1, 2010 at 5:55 PM
    rex99
    rex99 [OP] Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    ive read on here before about being able to unhook the battery to "reset" the ecu to accept a higher octane fuel, yet i couldnt find that thread in the search.
    my question for anyone that has done this is simple-- when do you unhook the battery?? before or after you fill up the truck??
    TIA
  2. Mar 1, 2010 at 7:22 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    What? Why would you need to reset the ECU to run a higher octane fuel?
    Disconnecting the battery for 30 seconds will clear your ECU's memory, but I've never heard of it adapting itself to different octane fuels.
  3. Mar 1, 2010 at 7:29 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    i remember reading it in a thread a while back-- i tried to search for it but i couldnt find it (i shoulda subscribed....)
    anyway, from what someone posted, if you unhook the battery the truck will like you said "adapt" to the higher octane and give you better mpg/ more hp
  4. Mar 1, 2010 at 7:31 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    ECU adjusts timing based on knock sensors...higher octane resists knock better, and allow the engine to open up additional timing after an adjustment period.
    This is why the 1GR-FE has different power ratings for 87 octane and 91 octane.
    No reset necessary...after a few tanks of 91+ the ECU will adjust on its own.
  5. Mar 1, 2010 at 8:13 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Yep.
    Personally though, i'd rather not wait the few tanks. A reset will force the ECU to relearn right away.
  6. Mar 1, 2010 at 8:30 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Spot on.
    Unplugging the ECU would not only reset the adaptive fuel tables, but also the shift cells for an auto, the idle strategy and learned behavior and so on. The other thing to remember is that that type of reset will take the computer to the base tables. New vehicles adapt VERY quickly compared to just a few years ago. Even long term trim is not so long term any more. I have seen vehicles adapt to induced changes in seconds on long term tables. They are really quick trying to maximize emission control.
  7. Mar 5, 2010 at 8:00 PM
    Second Childhood
    Second Childhood New Member
    San Diego
    99 SR5 4x4 supercharged
    TRD Super Charger added
    I installed a TRD supercharger on my 1999 that requires 93 octane. The mixture control adjusted itself in about 500 miles. Slick computer. My only problem is in CA you can only get 91 octane. Still no problem it adjusts. Once in a whjile I treart it to Octane Boost. Went from 195 HP to 275. A beast now.
