Resetting first gen abs light
Discussion in '1st Gen. Tacomas (1995-2004)' started by DanK83, Oct 10, 2019.
  1. Oct 12, 2019 at 3:31 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Pretty sure a scan tool will clear readiness codes too when you clear DTCs. My cheap one from Harbor Freight does, but at least I don't need to fiddle with radio settings.
  2. Oct 12, 2019 at 3:39 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I don't think basic obd scanners can read an abs light. Only CEL. I've never seen anything on mine telling me that my abs module is no longer there.
  3. Oct 14, 2019 at 3:33 PM
    DanK83
    DanK83 [OP] Well-Known Member
    Dan
    Maine
    2003 Tacoma SR5 V6 4X4
    So, the Autel CAN OBD2 MaxiScan MS300 arrived. Hooked it up and it cleared my check engine light that was on due to removing the second o2 sensor. The ABS light went from staying on steady to blinking 3 times, pausing for a second, blinking three times again, then staying off for 4 seconds. This cycle of blinking continues. At least it's not on constantly like it was but it's still not fixed.
  4. Oct 14, 2019 at 4:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's a Code 33, a right rear ABS sensor.
    http://www.testroete.com/car/Toyota/mr2 spyder/References/Technical Training/05 - Brake Systems/20.pdf?utm_source=ToyotaOwnersClub&utm_medium=ForumLinks
    Is that the sensor you replaced?
    Black DOG Lila likes this.
  5. Oct 14, 2019 at 4:39 PM
    jbrandt
    Justin
    You could definitely be right, there...
    Sounds like OP hooked up his new OBD scanner, and the ABS light threw a flash code, so seems like hooking up the OBD does the same as jumping the two wires as described above.
  6. Oct 14, 2019 at 6:13 PM
    DanK83
    Dan
    Maine
    The check engine light went out. It was on due to me doing away with the second o2 sensor. The abs isn't staying lit constantly. It blink 3 times, goes out for 2 seconds, blinks 3 times again, goes off for 4 seconds. Repeats. Check engine is still off. I deleted that code.
  7. Oct 14, 2019 at 6:15 PM
    DanK83
    Dan
    Maine
  8. Oct 14, 2019 at 7:24 PM
    jbrandt
    Justin
    Interesting, sounds like you might have a second one that's bad, which could explain why the light didn't go off before.
  9. Oct 15, 2019 at 7:38 AM
    DanK83
    Dan
    Maine
    I think I do too. The scanner said 'no codes' after I deleted the check engine light and the light went out. A couple of my friends are mechanics and have mote sophisticated scan tools. I just wanted to make the light go out. I'll have one of my friends hook theirsup and pin point the issue. Thanks for all your help!
    cruiserguy likes this.
  10. Oct 15, 2019 at 8:04 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    It takes at least a couple of drive cycles after clearing CEL with OBDII for trouble codes to reappear. Same with Jumping the pins to get a ABS flash signal code. CEL will turn itself off if repairs remedied the trouble code.
    DanK83[QUOTED][OP] likes this.
  11. Oct 15, 2019 at 12:32 PM
    DanK83
    Dan
    Maine
    The check engine light came back on so I plugged the obd2 back in. It gave me two codes. One is for evap system and more accurately the charcoal box that holds unburn fumes. It said, small in the code book. Not sure if the charcoal canister is bad or if there is a vacuum leak in one of the rubber hoses. The other code is for the heated 02 sensor which is the second one I did awaywith when I replaced the exhaust pipe. Apparently this scanner doesn't do ABS.
  12. Oct 18, 2019 at 12:33 AM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Random wait on I. Regards to that sensor, how hard is it to replace? I think mine is bad... both my fronts have a tip tie on them and the brakes are a bit weird when coming to a final stop on and off. Curious if you had a similar issue. They would kind of push back like the abs is locking up or something
  13. Oct 20, 2019 at 8:47 AM
    DanK83
    Dan
    Maine
    It's very simple to replace. One bolt holding the sensor in, a few attachment clips along the length of the cable and a plug in connection. It's a 1-20 minute fix. As far as I can see, my truck's abs system is in test mode or there is another bad sensor on one of the other three wheels. Bringing it to my friend that's a mechanic and has a scanner that reads all systems of vehicles.
  14. Oct 20, 2019 at 8:57 AM
    DanK83
    Dan
    Maine
    My brakes worked fine, I just got tired of having the ABS light being on for 5-6 years. I never had the feel of the brake pedal pushing back on my foot. Originally, I just put a bolt in as as plug instead of buying a sensor. I'll take pics of the cable routing if ya need it for reference. Like I said, they have some metal and some plastic connectors that attach thr the a-arm bracket, frame, etc.
