Resistance while turning and clicking coming from steering wheel help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruben526, May 17, 2017.
  1. May 17, 2017 at 5:27 PM
    Ruben526
    Ruben526 [OP] Well-Known Member
    Ruben
    Salem, Oregon
    2001 Tacoma SR5 Prerunner
    Solo MOTORSPORTS LT basic kit with king 2.5 8” coilovers Advanced fiberglass fenders all around Deaver J59 springs with rear shock relocation to outside frame 14” 2.5 sway away triple bypass sway away 2” 2.5 bump stops 35” general grabber X3 17” addicts Total chaos spindle gussets
    Need some help so I have resistance in my steering when I'm turning right mostly(steering does return) so Iv PB blasted the U joint behind the steering wheel, changed power steering fluid with atf d3, bled the steering and still resistance though not as bad as originally but it is still there and when I jack up the truck the steering is not a rough with the resistance but still there. I also had just changed out all LBJ and upper uniballs. So I'm prolly going to have to swap the steering rack out but today a new symptom when I make a left turn upon return to I trap position there clicking on the steering wheel it's self anyone experience this? What do you guys think? Thanks for the help just wondering what you all think it is and what parts need to be replaced
  2. May 18, 2017 at 1:12 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Airbag light on? Clicking could be the clock spring behind the steering wheel.
  3. May 19, 2017 at 3:03 PM
    Ruben526
    Ruben
    Salem, Oregon
    That is a good assumption actually but no lights on dash for me but I'll investigate that idea more thank you man
