Resistor help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jr124gamboa, Sep 3, 2014.
  1. Sep 3, 2014 at 8:58 AM
    jr124gamboa
    jr124gamboa [OP] Well-Known Member
    socal
    07 4x4 sr5
    airride airbags, bedliner,
    Does anyone know where I can find this resistor...it's for the overhead temp module or the exact measurement I know it's a 510 smd but I don't know the watts
  2. Sep 3, 2014 at 10:23 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Can you measure the length and width?
    It looks like it might be a 1206 size resistor, which
    means it's dimensions are (0.120"x 0.060"y), if so
    it will probably be 1/4 watt rated.
    If its bigger like a 2512 size, might be up to 1/2 watt.
    Digikey.com is your friend.
    Good luck.
    PC
  3. Sep 3, 2014 at 11:57 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Yup x2
  4. Sep 3, 2014 at 12:08 PM
    Collins
    North Carolina
    Also,
    Those are referred to as 'chip resistors' and from the pix
    looks like the resistance value is 5.1 ohm, 1% tolerance.
  5. Sep 3, 2014 at 4:24 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    My 510 resistor fell off of the board and I could not find it to solder it back on and fix the compass /temp display.
    What you are referring to is a surface mount (SMD) 51 ohm resistor.
    I went to radio shack and bought a 5 pack of 47 ohm 1/2 W resistors for $1.50
    These are the closest they had to 51 ohm and they work just fine.
    Now these resistors are not ment to be soldered onto flat surfaces but it can be done if you are good at soldering. Mine has been there for 3 years of some hard off-roading and it still works great. I have fixed 2 other TW members compass display using the same method and all still work well.
  6. Sep 4, 2014 at 11:12 AM
    jr124gamboa
    socal
    07 4x4 sr5
    Thanks for all the info I was pretty lost
    I think I'm going to go the radio shack route
