Resistor identification???
Discussion in 'General Tacoma Talk' started by AV8R4LIFE, Mar 18, 2024.
  1. Mar 18, 2024 at 7:12 PM
    AV8R4LIFE
    AV8R4LIFE [OP] Aircraft Mechanic
    Jonah
    St. Augustine Beach, FL
    Black/2004/Toyota/Tacoma/PreRunner/2.7L I4/2WD
    To anyone who's an electronics guru, what size resistor is this, and what are the specifications so I can order the same or equivalent replacement? Thanks!!!IMG_0979.jpg IMG_0962.jpgIMG_0969.jpg
  2. Mar 18, 2024 at 7:21 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Ugh. The color bands are gone. I have a chart but with them gone it’s pointless.
  3. Mar 18, 2024 at 7:25 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  4. Mar 18, 2024 at 7:28 PM
    AV8R4LIFE
    Jonah
  5. Mar 18, 2024 at 7:29 PM
    AV8R4LIFE
    Jonah
  6. Mar 18, 2024 at 7:40 PM
    0xDEADBEEF
    Can't really tell without understanding the circuit its in.
  7. Mar 18, 2024 at 7:40 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    It is definitely 0.33 Ohms 5%. Might be a power shunt for current monitoring or similar. Do you know what happened to fry it?
  8. Mar 18, 2024 at 7:45 PM
    AV8R4LIFE
    Jonah
    No, but it’s possible I put the LED dome light in backwards.
    davidstacoma likes this.
  9. Mar 18, 2024 at 7:56 PM
    tacoma_ca
    Maybe get wider shots for context. It is a dome light board behind a light diffuser?
  10. Mar 18, 2024 at 7:58 PM
    AV8R4LIFE
    Jonah
    It is the body ECU board. No idea about the diffuser.
  11. Mar 18, 2024 at 7:59 PM
    AV8R4LIFE
    Jonah
  12. Mar 18, 2024 at 8:24 PM
    tacoma_ca
    not really to me unless a current monitor shunt. curious how you know it is dome light circuit?
  13. Mar 18, 2024 at 8:45 PM
    AV8R4LIFE
    Jonah
    I don’t. But it’s the only thing that’s obviously blown and a few other guys that know more then I do have said that it is the problem. To clarify, the dome light will not come on in the door position. All of the wiring and the switch is intact and working correctly. The fault is at the body ECU, from what I’ve heard, it is that resistor.
  14. Mar 18, 2024 at 10:18 PM
    tacoma_ca
    Looks like it might be 2W. Maybe try 5W and see if it lasts longer?
  15. Mar 19, 2024 at 3:16 AM
    AV8R4LIFE
    Jonah
    It lasted 5 years with that resistor and the same bulb combo, so I would imagine with a 5W you’d be set.
  16. Mar 19, 2024 at 3:52 AM
    AV8R4LIFE
    Jonah
    Does it need a flame retardant coating or anything special like that? Or just any old .33 ohm +/-5% 5W resistor?
  17. Mar 19, 2024 at 9:20 AM
    tacoma_ca
    Really it shouldnt be frying in the first place but I have no idea what is going on in the circuit.
    https://www.digikey.com/en/products/detail/ohmite/25JR33E/823144
    If you want to oversize. This is an inch long. You can stand up one side to make it fit. If the leads don't fit through the board you can solder the biggest leads that do fit through, then twist and solder those to this. Don't drill the board unless you known it is only 2 layer. Else look for around 2W for the leads to probably be the diameter the board expects.
    0xDEADBEEF likes this.
  18. Mar 19, 2024 at 9:43 AM
    AV8R4LIFE
    Jonah
    Well it seems to be related to putting in LEDS for the dome lights, since I’m not the only one who has had the same thing happen.
    https://www.tacomaworld.com/threads/really-long-shot-on-dome-light-issue.803420/
    https://www.toyotanation.com/threads/03-tacoma-under-dash-fuse-box-help.1766312/
  19. Mar 19, 2024 at 10:13 AM
    0xDEADBEEF
    If I had to guess wildly…
    that beefy fet next to the resistor might be used to pwm the lights in order to dim them. That resistor is between the gate of the fet and probably the output of a microcontroller on the other end. The purpose of the resistor is to limit the gate current when microcontroller is rapidly switching to keep the output of the microcontroller happy. When you swap LEDs in instead of bulbs, it may be that the microcontroller keeps trying to fade the lights for longer due to the electrical differences between leds and incandescents, meaning the resistor spends more time than it should dissipating heat and overheats.
    Total guess based on a couple pics though,I’d have to get one on a bench to play with to really know.
    does it fade out normally with the leds installed?
  20. Mar 19, 2024 at 10:43 AM
    AV8R4LIFE
    Jonah
    I don’t remember if it did or not. It goes off instantly when you unlock with the fob and wait till it re-locks itself, or when unlocking with the fob and opening the door.
