Resolved - Did the dealer update my ECU and not tell me?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shaggy135, May 15, 2023.
  1. May 15, 2023 at 10:40 AM
    shaggy135
    shaggy135 [OP] Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    My truck was at the dealer recently and after I got it back, I noticed that my dash menus were out of order and my miles til empty has been raised. Its been over 300 multiple times now.
    I know, first world problems, but my OCD is curious, ha. With the menus, it used to take 3 clicks to the right to get to the tire pressure screen. Not its just 1 to the right. Also, my fully loaded setup gets about 240-250 miles on the full tank count down. The last 3 fill ups its been saying 320-310. I'm expecting this to keep dropping but I'm currently at 192 miles at slightly less than half a tank. So who knows, ha.
    Is there a chance that Toyota updated something and didn't tell me? My receipt just shows diagnostics, nothing else, ha. I'm waiting on a call back for confirmation.
  2. May 15, 2023 at 10:44 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Check your service order, it would be on there. Also, if they do a TSB update that changes your ECU ID there should be a sticker under the hood denoting the update and new ID. It's also possible depending on what you got done that they disconnected the battery.
    Chew likes this.
  3. May 15, 2023 at 10:51 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's absolutely possible it got an update. Depending on the issue, oftentimes the first step is to update software and see if it fixes the problem
    Chew likes this.
  4. May 15, 2023 at 10:54 AM
    Shellshock
    Iowa
    Sounds more like the battery got disconnected
    texbaz and 2022mgmtrdsport like this.
  5. May 15, 2023 at 10:57 AM
    shaggy135
    It went in for a clutch/transmission issue. More than likely they did disconnect the battery. Thats not my big concern. More about the update and them not even saying anything. I'll have to reflash my tune but I might test this out for a minute and see how it does.
    No new stickers under the hood either.
  6. May 15, 2023 at 11:00 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Just my personal opinion as a tuner, but I think if you went from a tune back to a stock tune you'd notice the difference fairly quickly.
  7. May 15, 2023 at 11:33 AM
    shaggy135
    Normally I would agree. It had been about 3 weeks since I last drove it. Ended up being a clutch issue, so I had my mechanic take care of that. He also did the accumulator delete. So I had both of those to adjust to as well.
  8. May 20, 2023 at 4:42 AM
    DevilsPineapple
    DevilsPineapple Well-Known Member
    Richmond
    Voodoo blue 2020 TRD off-road 6MT
    RRW sliders, lil b's hybrid front bumper, Evo 10s, rigid radiance fogs, Agency6 fairlead and flatlink, DRT cmr, SPC uca's, trimmed front fenders, RRW RR7-H 17x8.5 -12 offset, 255/85/17 Micky Thompson baja boss AT, Litner designs forged acs with two xl pods, UpTop Overland Bravo roof rack, rigid radiance series 40" amber backlit led light bar, oem bed lights, c4 inner fender liners, OEM TRD Pro grill, Nitro 5.29 gears, ECGS bushing kit, bilstein 5100s, 2/1.5 lift, old man emu 2888 coil spring, icon add a leaf, long range America fuel tank, OTT tune,
  9. May 20, 2023 at 5:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think if they did a tsb to upgrade the engine, and transmission's performance, it would have no effect on your dash readouts. A buddy had a 2019 trd, and had the tsb for that done. He never mentioned it, only saying it didn't change much of anything.
  10. May 20, 2023 at 6:25 AM
    shaggy135
    My mechanic tried one of those accumulator discs first, it leaked, so then he just replaced the accumulator with a hard line that his shop made.
  11. Feb 9, 2024 at 4:33 AM
    shaggy135
    Sorry to revive an old thread but I believe I figured out my dash menu issue. My battery has been disconnected a few times for mod installs in the last 6-8 months. I've noticed my menus had changed every time that it was reconnected. So that seems to be the culprit. I actually prefer the smaller menu option. I never really used anything but the speedometer, tire pressure, and roll/pitch screens. But now I know, ha.
    Chew and GTGallop like this.
