Resolved - Need help diagnosing vibration/noise - video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skcihs, Sep 25, 2024.
  1. Sep 25, 2024 at 6:38 PM
    skcihs
    skcihs [OP] Active Member
    2019 TRD OR 82k auto 1.5" lift.
    I've had this noise for about 20k miles. I thought it was loud tires, wildpeaks. I just had Ko3's installed today and same noise. Mechanic says wheel bearings are good. Sound is the same in 4wd and when cornering.
    What could be causing this noise?
    https://youtube.com/shorts/Dgkd2ApCry0
  2. Sep 25, 2024 at 8:14 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    You let this mechanic hear the noise, when person said wheel bearings okay? Rear diff get gear oil?
  3. Sep 26, 2024 at 4:05 AM
    skcihs
    The mechanic drove the truck at least twice and said it was tire noise, even with brand new tires. They said they inspected the wheel bearings and they look fine. I have never checked the diff oil. Never seen a leak or thought it needed to be checked.
  4. Sep 26, 2024 at 4:13 AM
    545 Well-Known Member
    2015 Access Cab
    Yeah sounds like the rear diff is howling
    bring it to a different mechanic
  5. Sep 26, 2024 at 8:13 AM
    STEELeR43
    Hawaii
    Just because no leak not answer. Probraly rear diff making big noise, especially conering is sign. Take it to another mechanic who knows what they are doing, if you not mechanically inclined.
  6. Sep 26, 2024 at 9:27 AM
    beef ranger
    beef ranger Well-Known Member
    19 OR 4WD 6MT DCSB CEMENT
    That’s either rear diff or mayyyybe something in the transfer case
  7. Sep 26, 2024 at 9:33 AM
    skcihs
    I checked the diff oil and it seemed full and clear. I didn't drain it. I feel it's coming from the driver's side front. It does it at all speeds from 1mph onward. I can feel it in the steering wheel and gas pedal. I think it's a wheel bearing or the needle bearing on front diff. I'm going to take it somewhere else next week.
  8. Sep 26, 2024 at 9:35 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Ok...what does he say the Noise is?
  9. Sep 26, 2024 at 9:45 AM
    skcihs
  10. Sep 26, 2024 at 11:26 AM
    MarquisDuSod
    MarquisDuSod New Member
    Dave
    2016 SR Tacoma M/T
    Slide underneath and check your exhaust connections? It’s an easy variable to remove from the equation.
  11. Sep 26, 2024 at 2:22 PM
    xerogs1
    xerogs1 Well-Known Member
    New Mexico
    2019 TRD OR DCSB AT Silver Sky Metallic
    Bartact Seat Covers, Cali Raised LED molle bed system, radio knobs and Subaru Tweeters, OCD interior parts, OEM Exhaust tip, dash cam, hood protector, various theft deterrent items. Still a WIP
    Are the tires rubbing on anything? It almost sounds like the knobby part of the tires slightly rubbing on a suspension part or in the wheel well. Good luck on troubleshooting. I hope you find out what is causing the problem.
  12. Sep 26, 2024 at 2:26 PM
    skcihs
    No rubbing. 265/75/16 on stock OR wheels. Thank you.
  13. Sep 26, 2024 at 4:48 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I would try disconnecting the front drive line maybe. And see if the noise goes away . It can also be a front cV Axle
    wilcam47 likes this.
  14. Sep 26, 2024 at 7:15 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sounds like a wheel bearing or bearings. I’d suggest finding someone else to diagnose this noise for you.
  15. Sep 27, 2024 at 1:34 PM
    skcihs
  16. Sep 27, 2024 at 1:54 PM
    STEELeR43
    Hawaii
    Driver side? Maybe get axle bushing kit from ECGS, to fix it. I don't have link.
  17. Oct 31, 2024 at 3:01 PM
    skcihs
    The noise/vibration has been resolved. Took it to toyota for the 3rd brake light recall. Had them diagnose the issue. They said the passenger front wheel bearing was bad. I had them replace it out of convenience, ouch that was expensive. 60% of the noise is gone and they said the driver front needs to be done as well. Had driver front done by local shop and now the noise is 100% gone. Also had both diffs and transfer case fluid done at the same time but not related to the noise. Thank you for the help!
