[Resolved] Rattling Head Rest
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Jun 28, 2023.
  1. Jun 28, 2023 at 6:42 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    During my last off-road venture the usual rattles in the truck were exceptionally loud. When I removed the passenger headrest, one of the more obnoxious rattles went away.
    Any ideas how I can troubleshoot that rattle other than completely removing the seat foam and then poking around?
  2. Jun 28, 2023 at 7:16 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The headrest is what rattles? Not something broke in the seat back?
    Do you need that head rest? Mine was gone when I bought the truck.
    Some tape to tighten things up .
  3. Jun 29, 2023 at 10:32 AM
    skeezix
    Colorado
    1998 Limited
    The headrest doesn't rattle since I took it out. Neither does the seat. :burp: (Just joking!)
    It made the same sharp, loud, metal-on-metal rapping regardless of how bad the dirt road was.
    No, I don't need it. Nobody else ever sits in the passenger seat and I would just take it out but there ain't no place in the garage to store it.
    Thanks for your suggestion! Before my next trip to the boonies I'll wrap some tape around the headrest legs and see if that makes any difference.
    Bivouac[QUOTED] likes this.
  4. Jun 29, 2023 at 10:34 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    take the headrest and bend the 2 bars slightly in or out,...then put it back in
    the tension will fix it most of the time
  5. Jun 29, 2023 at 10:47 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    You might try some heat shrink instead of tape. If one sleeve isn't thick enough, add another. Keep going until you're satisfied. Also, no sticky residue.
    Bivouac likes this.
  6. Jun 29, 2023 at 10:52 AM
    Madjik_Man
    Colorado Front Range
    TW: replace with Scheel-Mann seats.
  7. Jun 29, 2023 at 1:36 PM
    Bivouac
    Wow Your garage must be packed if you do not have room for a head rest.
    HondaGM likes this.
  8. Jun 29, 2023 at 1:39 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Fireball 00 likes this.
