Resolved - Seat heater issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shaggy135, Jan 20, 2025.
  1. Jan 21, 2025 at 2:11 PM
    shaggy135
    shaggy135 [OP] Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Found the problem. It was the ground after all. :facepalm::facepalm::facepalm:After crawling under and removing a bunch of zip ties, it was using a V- instead of a ground. Which is why it would only work when the lights were on. Removed that and put it on a bolt and it works like it should now.
    1 broken switch and a broken clip later. Thanks for all the helps guys.
  2. Jan 21, 2025 at 2:18 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Nice work!
  3. Jan 22, 2025 at 6:33 AM
    shaggy135
    Now lets see if my OCD kicks in to figure out how to dim those switches, ha.
  4. Feb 11, 2025 at 11:15 AM
    shaggy135
    Just for closure, I did figure out how to dim the switches. This set of heaters and switches uses 2 grounds. 1 for the heater and another for the switch dimming. They are tied together though. I had to split them up and use the regular black for the main ground - metal bolt and then the other black wire with a white stripe got moved to a V- for dimming. Everything works perfectly now.
    Steves104x4 likes this.
