RESOLVED - What do we think this noise is?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLtheP, Mar 19, 2024.
  1. Mar 19, 2024 at 6:11 PM
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Update: truck fixed under warranty for a bad driveshaft carrier bearing. See post #13 for more details
    All right folks, give me your best guesses. Please keep them helpful. Pulling into the alley behind my house this evening and I notice this loud chirp. I had been driving home and around town for a bit and heard nothing until I pulled into the alley. Noise bouncing off fences and such makes it more audible.
    2021 TRD OR
    6MT
    Everything on the truck relating to driveline is stock besides 5.29’s and 1” larger tires. Gears have been in for 25K, absolutely perfect. Stock height, no lift. Again, no mods except the driveline spins a bit faster than stock.
    The video is kind of crappy, I’m aware. Hard to catch any noise with the motor revving up in 1st. But if you listen close, it’s the chirping noise. It speeds up with the vehicle speed. When it’s making noise, it starts as early as 2mph. I’ll try to get a better video tomorrow in 2nd gear where the motor is quieter.
    I jacked up both the front and rear and got no noise. I put the front back down and ran the rear in gear to spin the tires in the air. Nothing. Had it in 4th going 20mph or so and nothing at all. Shook the tires, wheel bearings seemed okay.
    Went for a ride with my brother who I had drive around a bit in the alley and parking lot and the noise was gone by the time he was ready to go (of course). So the whole time I spent with him I found nothing, as it made no noise.
    At this point I’m just waiting to see when the noise comes back (not if, but when), and I’ll do more listening at that point. It seems to only be doing it going forward. In the video I was going back and forth (cut a lot of that out) and I really could only get noise going forward.
    But anyways, anybody heard this on their truck and figure it out?
    Wheel bearings?
    Driveshaft u-joints? (Non greasable)
    Driveshaft center support bearing?
    @Bishop84 @CygnusX191 any ideas?
    Appreciate any ideas I can get.
    Phlogiston likes this.
  2. Mar 19, 2024 at 7:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Wild ass guess but I'd say clutch damper springs.
    It could be u joints but they are more consistent. Clutch springs are affected by vehicle load and torque.
  3. Mar 19, 2024 at 7:08 PM
    BLtheP
    Plano, TX
    Didn’t think of those….weirdly enough it seems to only be making noise when going forward, not reverse, and it also seems to keep making the noise even when I pop it into neutral. It’s very strange for sure. I’d be surprised if it were a u-joint, hopeful it’s not that. Don’t want to deal with it.
  4. Mar 19, 2024 at 7:09 PM
    Bishop84
    I had the early 3rd gen and it had an odd squeak from the leaf springs, we resolved them by greasing the contact pads. Eventually a TSB came out.
    But leaf spring squeaks usually only make noise at low speeds.
  5. Mar 19, 2024 at 7:11 PM
    BLtheP
    Plano, TX
    Due to the volume of the noise vs everything else (wind, engine, tires) it’s hard to tell if the noise goes away or if I just can’t hear it. So far I really only hear it in the alley. So it seems to be pretty low speed, but it’s hard to say. I did bounce the bed up and down and got 0 noise so I’m not sure it’s the springs. I did think about it though. For now keeping an eye on it to see if it gets worse.
  6. Mar 20, 2024 at 5:46 AM
    BLtheP
    Plano, TX
    Thinking it’s the driveshaft carrier bearing…sigh
  7. Mar 20, 2024 at 6:42 AM
    fred 1954
    fred 1954 Member
    jason
    2016 tacoma 4x4 trd 4 door long bed
    ovtune
    where the rear driveshaft u/joints ever been grease ?
  8. Mar 20, 2024 at 6:52 AM
    BLtheP
    Plano, TX
    Factory non-greasable.
  9. Mar 20, 2024 at 7:19 AM
    BLtheP
    Plano, TX
    At the dealer trying to get it done under warranty. Plus side, I get a Tacoma as a rental/loaner so I can finally see what all the complaints with the auto are about.
  10. Mar 20, 2024 at 3:53 PM
    BLtheP
    Plano, TX
    Dealer confirmed I need a new carrier bearing. They said u-joints too but that part seems unlikely/surprising. Anyways, carrier bearing is on back order. Keeping the loaner indefinitely while they wait for parts. Covered under warranty.
    Chew and Stevie17 like this.
  11. Mar 20, 2024 at 3:56 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    That's cool..easy fix
    Stevie17 and BLtheP[QUOTED][OP] like this.
  12. Mar 20, 2024 at 5:39 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Great to see you got it sorted out
  13. Apr 1, 2024 at 7:10 AM
    BLtheP
    Plano, TX
    Final update, truck was fixed under warranty for $0. Turned in the truck the morning of 03/20/24 and got it back today, 04/01/24.
    They replaced:
    37230-09080 - Bearing set, center support
    04371-04101 - Spider kit, universal (u-joint) x1
    The center support bearing was the only part that was bad. The center u-joint has to be removed to replace the bearing, so that is replaced as well. The other u-joints were fine, as I predicted since everything was perfectly smooth all along.
    Glad to have my truck back and all seems well after picking it up and driving a bit. Definitely weird to be back in it compared to the automatic. Hopefully I get more than 47K out of the next one!
