Resonator Suggestion
Discussion in 'Performance and Tuning' started by TacomaGus, Jul 19, 2012.
  1. Jul 19, 2012 at 2:16 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    Just put on a set of JBA Long tubes on monday and I'm loving the power! However I've got the dreaded rasp since their paired with my aero 2525. The rasp is really only bad upon cold starts, and its really annoying, but once it warms up, I really like the sound.
    My questions are A. will the cold start rasp eventually subside? Because it seems like the rasp is dying down after less and less run time over the past couple of days.
    and B. if i will also have the cold start/ weather rasp, then what resonator do you guys recommend? I really like the tone of the aero at low rpms and I also prefer it loud, and I really LOVE the sound and it has now at idle so I'd prefer not to lose that. Just keep the low idle rumble and volume at wot without the rasp
  2. Jul 19, 2012 at 2:23 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Look up Vibrant Resonators and get one installed in line before the Muffler, should eliminate most of your rasp. If that's not enough swap out the 2525 for a 2525XL (Resonated muffler), that should guarantee to negate almost all rasp from your truck :cool:
    Here's the Part you want
    1793 - 18" Resonator (2.5" IN/OUT) or you can get the larger OD Resonator 17930
  3. Jul 19, 2012 at 2:26 PM
    TacomaGus
    Gus
    Morgantown, WV
    ya i know a lot of people run the vibrant resonators, I'll look into one, thanks man. I just have no experience with any sort of resonator, and don't want to lose any volume or rumble, just rasp.
  4. Jul 19, 2012 at 2:28 PM
    theduck911
    Max
    Locked and Geared!
    Shouldn't change the noise to much, slightly, but it's too be expected when putting in a resonator. It's a compromise to eliminate the rasp. :cool:
  5. Jul 19, 2012 at 3:08 PM
    TacomaGus
    Gus
    Morgantown, WV
    just ordered a vibrant resonator as per the suggestion. Went with the smallest one I could find (2.5" in/out, 4" tube and only 12 inches long) with the thought that the shorter the length the more volume it will have, like it is with mufflers...
  6. Jul 19, 2012 at 11:29 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    nice dude it seems like you have sampled almost every muffler worth bolting onto our trucks lol. i took your advice and went with an aero and i'm pleased as punch with it i'm all stock save for the afe pro dry filter and snorkel then the muffler 2525 non res. sounds beastly on my 4 banger actually surprised me. i was not expecting that muffler to sound as aggressive as the flowmaster it was replacing.
  7. Jul 20, 2012 at 8:49 AM
    TacomaGus
    Gus
    Morgantown, WV
    ya its def the best sound out there with all your cats still on. It still sounds amazing now 2k RPM and lower but after that its just too much.That rumble is still there at the higher RPMS but the buzzing is too much to handle lol. Hopefully this small resonator will help me keep that aero sound mostly
  8. Jul 23, 2012 at 12:33 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Exactly what I want to do!!! I want long tubes!!!!
  9. Jul 23, 2012 at 2:09 PM
    TacomaGus
    Gus
    Morgantown, WV
    You don't notice the low end power lost, but the powe above 2k rpm is def there! I just haven't been really able to enjoy them cuz of the damn rasp, but resonator is supposed to come in tomorrow in be on wednesday or Thursday so well see. I just hope I still won't have a ton of rasp with the smalles resonator, but I love the rumble :D
  10. Aug 26, 2012 at 6:12 PM
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
    Any updates on this, Gus?
  11. Aug 27, 2012 at 12:43 PM
    TacomaGus
    Gus
    Morgantown, WV
    I put in the 12 inch vibrant resonator, and there is still some slight rasp on cold start, but it's awesome once it's warm! If you wanted to eliminate all rasp at all times, then the 18 inch may work better, or the ultra quiet version
  12. Aug 28, 2012 at 10:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    You ever get any drive-by video clips, TacomaGus?
  13. Aug 29, 2012 at 5:16 AM
    TacomaGus
    Gus
    Morgantown, WV
    Negative, and prob wouldn't be able to for a while. Back at school now and real busy...
