Restoring a rifle
Discussion in 'Guns & Hunting' started by NraFan, Apr 12, 2010.
  1. Apr 12, 2010 at 8:00 AM
    NraFan
    NraFan [OP] Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    My father in law just handed me a rifle that has been in the family for a long time. He asked if I could get it cleaned up for him so we can take it out with us the next time we go shooting. Here is the situation:
    This is an old Springfield / Stevens model 15.
    The barrel is covered in surface rust, some of it looks bad.
    The wood stock is in fairly decent shape with minor dents and dings.
    So I know wood work and the stock is going to be easy. Some Tru-oil and sanding and good as new. The barrel is another story. I have been told that a lot of gun oil and super fine steel wool should help. If that doesn't work, do you have any suggestions on a good product I can use to refinish the barrel myself? I have read up on some cold bluing products, and some have recommended Brownells Alumahyde II. Anyone here have any experience refinishing metal gun parts? How about a good shop in southern california? Any help would be great. I would love to put this gun back in tip top shape and suprise the hell out of him. Thanks!!
  2. Apr 12, 2010 at 11:40 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    no help here but good luck! oh and pics?!
  3. Apr 12, 2010 at 11:45 AM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    i've re-done a 12ga barrel that was in pretty bad shape. oil would not have done the trick. i used steel wool got down to the bare metal and used a kit i got at cabelas. iirc i think it was called wonder blue or blue wonder or something. good quality stuff very easy to use. HORRIBLE SMELL. lol.
  4. Apr 12, 2010 at 11:45 AM
    ak47
    Anthony
    Washington
    stock 2nd owner
    oh and post pictures for sure!
  5. Apr 12, 2010 at 12:31 PM
    NraFan
    JT
    SoCal
    I've been reading up on the Blue Wonder, seams like the route I will probably take. I will try to post some pics tonight if I get a chance.
  6. Apr 12, 2010 at 12:59 PM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    You should try Bain and Davis i used them when i lived in so. cal. they are in San Gabriel. I had them re finish my m1 did an outstanding job and it was very affordable.
  7. Apr 12, 2010 at 1:06 PM
    BSPDX
    BSPDX Well-Known Member
    The blue wonder product works pretty well, looks good & really easy to use. Good luck with the restore!
  8. Apr 12, 2010 at 3:15 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Make sure it doesn't have any collectors value before you start fixin' on it.
    You'll lose whatever collector value exists.
    FYI
  9. Apr 12, 2010 at 3:30 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    cold bluing process is pretty straight forward. i've used a number of them with great success. my favorite is a kit made by birchwood/casey(should be fairly easy to find online.
    a couple of pointers for you:
    1. clean clean clean and clean some more if there is any oil or fingerprints left over from sanding it will effect the bluing.
    2. follow the instructions closely.
    3. before you blue it wetsand all the metal down with 1000-1500 grit sandpaper(this will add to the sheen of the final product. the shinier it is the better
    4. when you finish the bluing and everything is dry apply a generous amount of gun oil to everything metal(if you dont rust will start to form immediately)
  10. Apr 14, 2010 at 1:05 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I'd like to see this project documented with pics. :)
  11. Apr 14, 2010 at 4:35 PM
    spp
    spp OC, Kalifornia
    OC California
    If all it is is just light surface rust a friend of mine swears by FLITZ to restore the bluing shine without damaging it.
  12. Apr 14, 2010 at 4:47 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    SCRUB!!! :devil:
    Good luck on the project Devil Dog. Oh and pics or youre lying. . .:devil:
  13. Apr 14, 2010 at 4:58 PM
    mandzach
    mandzach Well-Known Member
    You will destroy the value of the piece if you restore it.
    Clean it, oil it and put it away for the next gen.
  14. Apr 14, 2010 at 4:59 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I've worked with a few of the cold bluing products mentioned previously.
    They are really simple to use and look good. Only for a while though.
    I practiced the method with an old Sears (Yes, Sear Robuck sold guns back then!) 20 Gauge my father game me. Unfortunately all these cold processes wear really easy when you use the rifle. Some would dis-color under heavy use. It also doesn't seem to stand the time with cleaners. After a hunting season (200 shells and 3 months) I had to redo it. After the third time, I got it blued by a gunsmith for like $100 (circa year 2000 prices) including the action. It's been immaculate since, except the barbed wire incident of 2006.
    So all I'm saying is, if your going to hang it up or leave it in the vault, the cold blue will be no brainer or wiser to except the keen eyed collector.
    I have no experience with the black oxide method or it's durability.
  15. Apr 14, 2010 at 5:00 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    Sounds like you got a lot of good advice........for gun oil (CLP), I recommend GUNZILLA awesome stuff.
  16. Apr 14, 2010 at 5:10 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    17' MGM DCLB SR5 4x4
    I restored an enfield WWII 30-06 last year, cleaning the rust off and re-bluing is pretty easy, if your looking to get it back to working condition, and not just looking good condition I would read up on how to fully disasemble it and clean the hell out of the barrel and the interior. I've had pretty good luck with the cleaner/oil all in one products like remoil (someone is going to give me hell for that). basically spray it on, give it 10 or 15 minutes, wipe the piece down, repeat till it wipes clean. I probably spent 20-25 hours just cleaning out that enfield before I started any restoration in order to get it right, but it was worth it in the end.
  17. Apr 14, 2010 at 5:18 PM
    USMC Mex
    USMC Mex Active Member
    Sun City, CA
    10 PreRunner TRD
    Just gettin started!
    Jeff Tandy Gun Finishing in Hemet!! He does DAMN good work and is very reasonable. I have had several weapons refinished by him and have recommended him to several of my buddies all with great success. He has a full blown gun smithing shop that he runs out of his residence. Super guy but be warned.....HE LOVES TO TALK!!
