Results from the ECGS front diff bearing replacement?
Discussion in 'Technical Chat' started by smartmonkey, Jan 28, 2013.
  1. Jan 28, 2013 at 6:08 AM
    smartmonkey
    smartmonkey [OP] Member
    Bangor Maine
    2011 Tacoma SR5
    Hey Folks. After troubleshooting the vibration in two wheel and then 4WD. I have narrowed it down to the out of clearance bearing on the driver side front diff. the CV shaft is sloppy at the diff as well. For those who opted to replace the needle bearing with the east coast gear supply bushing, Has this cleared up the cyclical groan/vibe. Has toyota elected to recognized the forums findings as of now? Im planning on addressing this problem... 2011 tacoma AC w 30k.Vibes since 28K. Thanx in advance
  2. Jan 28, 2013 at 11:42 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
  3. Jan 29, 2013 at 11:55 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I had a front end noise but it was wheel bearings. I did the ECGS bushing because the CV was very sloppy.
    End result, noise was from the wheel bearings. Everyone I have read about with the noise in 2WD but goes away in 4HI is the needle bearing.
  4. Jan 29, 2013 at 6:22 PM
    ms4x4outlaws
    ms4x4outlaws Well-Known Member
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    happy with my ecgs bushing! not hard to do if you have the right tools...
  5. Feb 3, 2013 at 10:25 PM
    smt328
    smt328 New Member
    Orange County
    '11 Dbl Cab TRD Sport 4X4
    leveling kit, tires
    New to the blog...Many thanks to all who provided input on the problem of vibrations. I picked up a very noticeable but intermittent vibration at 60,000 miles. Although I had a leveling kit installed at about 10,000 miles, I never had a problem until the 60,000 service was done with all the recommended services associated with off road use. The source of the vibration was difficult for the service techs to identify but based on your members comments and the ECGS video that followed, it was determined that the likely source was the needle bearing on the left side of the front diff. The original Toyota part was replaced with the ECGS part and the vibration has been completely eliminated. Thanks again for sharing your experiences.
  6. Feb 3, 2013 at 10:45 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    I am happy with the ECGS bushing. I have a full 3" lift, with the vibe in 2wd. 4wd it went away. Replaced the needle bearing, and BOOM. Problem solved. I only have 2-3k km on the bushing as of now.
