Retain OEM bluetooth mic and XM antenna?
Discussion in 'Audio & Video' started by deeve, Apr 18, 2016.
  1. Apr 18, 2016 at 9:10 AM
    deeve
    deeve [OP] Well-Known Member
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    Hello, I am looking at upgrading my stereo and am not much of a radio guy. Ive been lucky in that my past cars has a pretty good factory system. My non JBL system is the upgraded version but still kinda sucks :) I would like to get something that had carplay, nav, XM and handsfree calling but uses the oem mic and XM antenna. Is that possible?
    Ive looked on Crutchfield and I see I can retain the steering wheel controls, but does not mention the mic and xm antenna. I would think there is something to do that....
    Thanks!
    DAVE
  2. Apr 18, 2016 at 9:45 AM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    I recentered my search-fu and found some answers. Looks like it is easier and better to use the mic that comes with the aftermarket system.
  3. Apr 19, 2016 at 10:35 AM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    No go on reusing the mic, might be able to mess with the xm antenna. Another option is using the XM app on your phone to bluetooth/aux in on your new headunit.
  4. Apr 19, 2016 at 3:24 PM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    I had thought about using the XM with my phone. Id be curious to see what the data hit would be. Also got me thinking...one of the things I like about the XM is that it works when no other radio will. Im betting that if I dont get a regular radio station very well at a location, my cell will be out too.
    tacotacolove77 likes this.
  5. Apr 26, 2016 at 7:50 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    You'll need 3G or better cellular connection to stream data.
    I stuck with stock radio and upgraded rest of the trucks audio. BT connection is solid. HU Apps work great. It's low profile and decent sound for what I want.
  6. Apr 26, 2016 at 8:10 PM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    What did you do to upgrade your stock stereo components, if I may ask?
  7. Apr 26, 2016 at 8:38 PM
    UBYBC
    2014 Tacoma TRD OR
  8. Apr 26, 2016 at 8:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The bluetooth microphone receives power from the stock headunit. If I remember correctly it is somehow tied into serial data and or it uses low voltage output, not worth the trouble if you ask me. Use the new headunits mic..
    As far as the Sirius XM, you can hack the wiring, as stock from the sharkfin uses a standard style plug, which then gets hooked up to buly some garbage proprietary Toyota extension plug. I am still trying to get that hooked up without making a huge mess. It should be right under the drivers kick panel inside a loom if you want to give it a shot. I still need to hook that up and my backup cam, but no one seems to have a damn clue as to where the factory plugs for the cam are on the JBL equipped trucks for 2012 and up. Everyone keeps referring back to the how to which pertains to 09's and below in every other thread I have read.
    If it doesn't involve lifts, or a lightbar, no one ever knows a thing around here.
  9. Apr 27, 2016 at 8:20 AM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    UBYBC[QUOTED] likes this.
  10. Apr 27, 2016 at 8:20 AM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    Have you tried posting something up on toyotanation.com ? They seem to have some very knowledgable audio folks on there
  11. Apr 27, 2016 at 12:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not yet. I'm actually not even a member in there at all.
  12. Aug 8, 2017 at 8:50 PM
    Tcgator
    Tcgator Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
    Sorry to revive an old thread. But does anyone by chance happen to still have their stock mic? And would be willing to part with it ?
