Retaining factory mic location
Discussion in 'Audio & Video' started by Kyleinator, Jul 31, 2017.
  1. Aug 22, 2019 at 11:57 AM
    #141
    xsquid
    xsquid Well-Known Member
    SF Bay Area
    The original post referenced above is a few years old so was wondering if wiring would be the same for a 3rd gen truck?
  2. Aug 22, 2019 at 12:29 PM
    #142
    Kyleinator
    Kyleinator [OP] Well-Known Member
    Kyle
    SoCal
    2013 SR5 5 Lug
    Fog lights 3.73 Third Member
    From my research 3rd gen and 2nd gen mics are wired the same, but I've never taken apart a 3rd gen.
    xsquid likes this.
  3. Sep 2, 2019 at 2:23 PM
    #143
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Did the wiring mod on the stock headphone: it's very easy to access, just pry the console away from the roof. All the wires have connectors. While I had everything taken apart, I came up with an easier and more reversible method to wire the microphone than the Tundra guy has described. I took photos and will post later if this works. However...
    After getting the mic prepped, I moved to the other part of the task: finding the brown/yellow wires on the K7 (rearview camera) connector.
    Turns out there's two brown wires and no yellow wires. One of the brown wires appears to be hooked into the rear video signal, matching with a black wire on the other side, which suggests it's a ground (and not positive, like the instructions say -- but then there's two browns so who knows). Super frustrated since I was all geared up to make this mod happen. Had to stop work and button things up to let a storm pass. When I'm feeling it again, I will break out the multimeter and try to trace where the mic wires end up in the factory harnesses.
    GMAN62465 and DaMaDo like this.
  4. Sep 15, 2019 at 11:54 AM
    #144
    Angel Rivera
    Angel Rivera Well-Known Member
    Angel
    Southern California
    2017 Toyota Tacoma TRD Off-Road Double Cab
    Ditch lights, front LED light bar, leather seat covers, bed tonneau cover.
  5. Sep 15, 2019 at 11:54 AM
    #145
    Angel Rivera
    Angel
    Southern California
    Bummed I so wanted to purchase this product
  6. Sep 24, 2019 at 10:25 PM
    #146
    NEPAChuy
    NEPAChuy Well-Known Member
    Jeremy
    2018 Tacoma TRD OR Blue Pearl
    Anyone have tips for routing the drop-in mic from OP? I have the overhead console out and the drop-in mic inserted in the console, but now I need to route the 3.5 mm adapter to the HU.
  7. Oct 26, 2019 at 6:09 PM
    #147
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    I would also be interested in any tips with routing the mic wire
    GMAN62465 likes this.
  8. Aug 4, 2021 at 7:49 AM
    #148
    AVIOTREN
    AVIOTREN Member
    AL
    Cape Cod
    2008 Access TRD Off Road Rugged Trail Silver Streak Mica
    fish the wire between the roof and ceiling from the console to the A pillar then down under the steering wheel above the pedals.
    HNLSFO1 likes this.
  9. Mar 4, 2022 at 10:59 AM
    #149
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    I have a Teyes CC3 head-unit that I just purchased. I asked Teyes about using my OEM mic and they said the OEM mic can be installed into #19 and #20 of socket A on the harness. Having never seen where the OEM Mic terminates to the original Entune stereo my question is this. Are there only two wires (plus and neg) that terminate here?
  10. Jun 24, 2022 at 7:59 PM
    #150
    rescuric
    rescuric New Member
    Rick
    Near Atlanta, GA
    2015 Tacoma XSP-X
    So, I just faced the same issue with my 2015 Tacoma Pre-Runner. I wound up Splicing the 3.5mm plug to the black and gray/white wires in the #5 top and bottom locations (I'm sure there's an official number) of the primary radio plug from the vehicle harness. I, then, cut the factory microphone from the circuit board with the black/white wires attached. I spliced these black and white wires to the light brown and black wires from the circuit board plug. This left the red and dark brown wires unused.This also eliminated the circuit board. After securing these splices, I stuck the 3.5mm plug into the back of my new Kenwood DNX697S. I mounted the factory microphone back on the circuit board box (sans board), stuck it into it's original receptacle on the back of the overhead panel, and put the panel back together...voila. This kept my factory look overhead while using the factory wiring and eliminating the need for me to route the long aftermarket microphone wire down the "A" post, over the steering column, and over the river and through the woods. However, the method is pretty irreversible. But, why would I want to? The factory microphone now uses the microphone amplification in my new aftermarket stereo (which has an adjustable amplification) and I keep the great sounding factory mic. The Kenwood also has microphone background noise reduction so, while I lost the factory mic amp, I gained a whole treasure trove of amplification and other tools to adjust the voice input. Took about an hour including soldering the splices, isolating the same with heat shrink, and re-securing the wiring harnesses to look like factory work.
    volte, whiting1977 and NmapFE like this.
  11. May 22, 2023 at 7:32 AM
    #151
    volte
    volte Well-Known Member
    Dale
    Denver
    2014 Magnetic Grey Tacoma TRD OR 4x4 V6 MT
    ICON Stage 9 Lift
    Most excellent! Would you be inclined to show photos?
    What ever happened to this adapter project? Wondering what it would take to start up again. Really wish there was a model we could 3D print. All these unique connectors drive me nuts. I’ve learned over my short time here on earth that said frustration is usually due to ignorance; half the battle is just knowing the dang name of things. Then another 1/4 is finding where/how they’re made and then getting it made.
    I wish the folks that make these head units and do the harness for all the connectors would just make one for the factory mic too. Is there something technically special about the mic that calls for a full replacement with a standard 3.5/2.5mm mic or is it just a snowflake harness that makes it special?
  12. May 22, 2023 at 7:49 AM
    #152
    uf20wop
    uf20wop Well-Known Member
    Greg
    PBG, FL
    2013 Super White DCSB TRD OR
    The adapter project is definitely dead.
    I went around this with rescuric and then i ended up drawing up this diagram:
    However I ended up just pulling the stock mic out of the headliner and putting the aftermarket mic with the RCA plug in the little box the stock mic is mounting in and just routing the cable above the headliner and down the A-pillar on the passenger side. Sound quality is great and no one complains, for me it was much easier than doing all the soldering.
    armyofsquirrels likes this.
  13. May 22, 2023 at 7:51 AM
    #153
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    Ok I appreciate the info. This is what I was considering doing as well. To be clear, do you mean you pulled the OEM mic out of that little slotted housing inbetween the two lights, and stuffed the mic in there?
    P.S. Your attached photo isn't coming through for some reason
  14. May 22, 2023 at 7:56 AM
    #154
    uf20wop
    Greg
    PBG, FL
    i'm at work but so i can't take any pictures but essentially i just removed the stock mic from the area it sits in stock and replaced it with the aftermarket unit... i *think* i used a couple dabs of hot glue or double sided tape or something to keep the aftermarket mic from bouncing around in the compartment.
  15. May 22, 2023 at 8:48 AM
    #155
    rescuric
    rescuric New Member
    Rick
    Near Atlanta, GA
    2015 Tacoma XSP-X
    That works just the same. I just don’t like the stray wires in mine. My method just splices the mic and 3.5mm plug to each end of the factory wiring.
  16. May 23, 2023 at 5:59 AM
    #156
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I wrote up a DIY that shows you don't need to run a new mic cable. No one bothered to respond to it, but here it is: https://www.tacomaworld.com/threads/how-to-diy-oem-mic-retention-2014-carplay-android-auto.799856/
  17. Jun 28, 2023 at 8:48 AM
    #157
    f18taco
    f18taco New Member
    Drew
    2005 Toyota Tacoma Double Cab 4x4
    are you still doing this? I'm interested.
