Retarded Newb Question. 285's? 5100"s??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chazmanian, Aug 25, 2009.
  1. Aug 25, 2009 at 11:59 AM
    Chazmanian
    Chazmanian [OP] Well-Known Member
    Colorado
    Stocker
    I must be a retard.
    I searched and ended up comfused.
    So I'll be simple as I just need one guy who has this combo to say "Yay or Nay".
    2009 A-Cab TRD 4x4 Sport.
    Just bought a set of 951B Moto Metals 17X9 with -12MM Offset and 4.5 Backspacin'.
    Called Sonny to order the 5100's to take the truck up 2.5" in the front.
    Assuming my 09' came with whatever the rear leaf TSB is?
    If I remove the front mudflaps all together will this combo Fly or Die?
    Thank You Gents!!!
  2. Aug 25, 2009 at 12:05 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    yup you can do it, not because of the 5100's but because of the offset rims
  3. Aug 25, 2009 at 12:07 PM
    Chazmanian
    Colorado
    Stocker
    That what I was hoping....Sonny at Down South Motosports was thinking it would straight rub when the steering was locked.
    I just want the 285's on the derned truck!!
    The mudflaps will require complete removal right?
  4. Aug 25, 2009 at 12:08 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    remove mud flaps and you will have to cut some plastic in your fender that should be it as far as I know you would rub on the ucas if you had stock rims, but seeing how you dont you should be all good. Might want to wait till someone else replies that has done it tho, as I havent but have been doing my research cause I plan on doing the same thing as you.
  5. Aug 25, 2009 at 12:14 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    that should work with complete front mudflap removal and trimming of your inner fender well, the black plastic stuff, just cut that "nub" off that's hanging there and you shouldn't have any rubbing issues
    i have 285/70/17s mounted on revolvers with -12 offset and 4.53" bs and no rubbing what so ever with no front mud flaps and trimmed wheel well
  6. Aug 25, 2009 at 12:17 PM
    Chazmanian
    Colorado
    Stocker
    Well if its any consolation it didnt cost much...Yet:eek:
    17x9 Moto Metal 951B's $550.00 shipped with lugs.
    Bilstiens 5100's front only $172.00 shipped.
    Bilsteins installed and truck aligned $175.00
    285/70/17 BFG AT's $865.00 mounted and balanced.
    Grand Total= $1762.00
    Will add rear Billies at a later date if the front works our without having to do some indepth lift kit deal....
    Hopefully this dosent become some insane project. I want it to plug and play...I have a Harley that takes all my spare cashola!!
  7. Aug 25, 2009 at 12:19 PM
    Chazmanian
    Colorado
    Stocker
    Simon I'm begging for a side shot of your truck!!
    You have the 5100's set at 2.5" without adding new control arms to address alignment issues??
  8. Aug 25, 2009 at 12:20 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    did you get the tire pressure sensors?
  9. Aug 25, 2009 at 12:20 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    I have mine at 2.5 with stock control arms
  10. Aug 25, 2009 at 12:23 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    I am just getting my alignment done as I type this I will post pics of mine probably tomorrow
  11. Aug 25, 2009 at 1:56 PM
    VolNut
    VolNut Well-Known Member
    Rick
    TN
    Interested to see if it aligns good and how it rides. I'm undecided between 1.75 & 2.5. Thanks
  12. Aug 25, 2009 at 1:57 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    it rides good a lot stiffer than the stock shocks but imo a way better ride
  13. Aug 25, 2009 at 2:54 PM
    rd263
    rd263 Banana Republic
    Southeast of Disorder
    2006 SW SR5 4X4 AC
    Billy 5100's front,5% tint rear,20% sides,35% full front,Kenwood head unit,DRL mod,AFE CAI,Thule rack system,TSB rear leaf upgrade,Hella headlamps,Vent visors,Led brake lamps,Led backup lamps,clutch squeak TSB,TO bearing fixed,Debaged,100 watt fog lights ,Popnlock,shorty antenna,door sill protectors.
    I have mine set at 2.5 an it rides as it should, nice and tight !
  14. Aug 25, 2009 at 3:01 PM
    Simon2150
    Austin, TX
    Check my gallery for pics. When I had my alignment done the only thing that wasn't to spec was caster it was off by a little. Toe and camber were good. I do have the aal on the rear
