Retired - Maintenance ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Oct 17, 2022.
  1. Oct 21, 2022 at 6:04 PM
    #41
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Kaboom
  2. Oct 21, 2022 at 6:19 PM
    #42
    Waasheem
    Waasheem
    2007 xrunner
    Try to imagine a small business. A truck pulls in to deliver 1 pallet of product. They start the forklift, unload the 1 pallet, turn it off. The engine ran for less than 3 minutes. Repeat the same over and over. When it’s time to change the oil, this comes out.
  3. Oct 22, 2022 at 2:48 PM
    #43
    Nordberge
    Nordberge Well-Known Member
    2011 TRD Off-Road PreRunner
    It is supposed to be a joke when we say "Chai Pumpkin Spiced Oil"
  4. Oct 22, 2022 at 2:52 PM
    #44
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    One of the motorcycle dealerships near me has this problem on ALL their bikes. They don't have enough space, so every morning the staff rides each bike 50ft out the front door to display them in the parking lot, and every evening they ride the bikes back into the building. The bikes that don't get test ridden frequently (or sold quickly) get the ol' milkshake oil in no time. The engines run just enough to generate moisture as a byproduct of combustion, but never get hot enough to dry off.
  5. Mar 3, 2023 at 9:44 AM
    #45
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    https://www.youtube.com/watch?v=WRnrS3TKGE4
    davidstacoma likes this.
  6. Mar 3, 2023 at 5:41 PM
    #46
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    D3 or mobil filter?
  7. Mar 3, 2023 at 6:00 PM
    #47
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I'm only putting 10-12K per year on my truck now. (currently at 122k, purchased in 2021 with 104k.) I think you're good on everything for mileage interval except the oil. I have been changing mine every 6 months and since I'm not towing anything, I'm using Castrol conventional 5w30 in the summer and synthetic Mobil1 5w30 going into the winter. I have changed the transmission fluid and coolant in the last 12 months. Next will be the diffs and the xfer case, and then the plugs since I don't have the service service history except for the oil, which showed regular oil changes at right around 5k interval since new. Judging by the condition of the trans fluid, coolant and the view through the oil fill, I believe the truck was serviced according to the Toyota specs. The diffs and transfer case plugs all show hints that they have been off at least once as well. YMMV
  8. Mar 3, 2023 at 7:42 PM
    #48
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Taking mileage and extreme circumstances out of the question, I have never heard of changing oil every 6 months, especially with synthetics. Am I missing something, because that sounds like a complete waste of time and money.
  9. Mar 3, 2023 at 7:47 PM
    #49
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends how it's driven, if you regularly just drive a couple miles at a time where it never gets up to temp you should be changing the oil on a time basis rather than mileage. If you drive it longer distances where it fully warms up your probably safe doing it on a mileage basis.
  10. Mar 3, 2023 at 7:52 PM
    #50
    topoutman
    Ellensburg, WA
    I figured you would change it sooner based on those conditions, just not as soon as 6 months! :notsure:
  11. Mar 3, 2023 at 7:59 PM
    #51
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    To each his own I guess, IMO it's better to change it too much than not enough. The average vehicle I see through the shop the engine looks terrible on the inside from lack of oil changes, oil costs alot less than a new engine.
    JAGCanada likes this.
  12. Mar 4, 2023 at 1:04 AM
    #52
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    D3 is stock, not oversize. I currently have a Wix XP 51515, before that, a Purolator PL30001. The Mobil1 equivalent is M1-301A.
    Reggie4x4[QUOTED] likes this.
  13. Mar 4, 2023 at 1:25 AM
    #53
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    This, very much so. Combustion byproduct water vapor is one source, another is just ambient humidity (climate depending) which gets pulled into the crankcase by the mild vacuum that occurs naturally in any semi-sealed space whose temperature drops fairly quickly.
    Engine oil needs to get up to some decently-hot threshold for a long enough period to drive out accumulated water vapor/liquid. In winter months when it's damp/cold outside, at the end of a 30 mile drive w/ a 1200 ft vertical climb & getting the engine nice and hot, upon parking & opening the oil filler cap there is a stream of vapor coming up & out. Engine is not overheating, it's at normal operating temp of ~180ºF coolant.
    I know it's water vapor (not smoke or oil vapor) because it will fog a cool piece of glass, but the fog evaporates from the glass without a trace when removed from the vapor stream. No residues or odors.
  14. Mar 4, 2023 at 3:33 AM
    #54
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    I have been doing the 5000 mile or 1 year oil changes the last 3 years since I retired. Which ever comes first with my 3 vehicles. I use synthetics in all 3.
    I also work on my own cars and recently sold my 65 Galaxie 500 that I had for 30 years. With conventional oil I was only doing oil changes every 3 years because the car was only being driven 1500 miles a year.
    I always watched the oil closely and visually I never saw anything that concerned me. The oil still looked like new oil when it was drained.
    I sometimes think when 2500 mile oil changes are being suggested its just a business tool to get into your wallet. Mechanics I have talked to say it doesn't hurt to change it early but it depends on how you drive your car and maintain it as well. I have been driving since 1974. 0 engine failures.
  15. Mar 4, 2023 at 4:32 AM
    #55
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'm retired and don't drive a lot (2007 with 34,250 miles.) I do the auto trans, front/rear diffs, and transfer case every 15,000 miles which comes out to around every 7 years. Engine oil gets changed out every 1,000... about every 6-8 months. With short trips, some offroading, and towing a boat the oil (Mobile 1) is dark. All other fluids get changed about every 10 years.
  16. Mar 4, 2023 at 9:34 AM
    #56
    george3
    New Jersey
    WOW ! 16 years and like new - doesn't say where U R - if not in the rust belt with salt covered roads your truck should last longer then both of us. Thanks.
    OffroadToy[QUOTED] likes this.
  17. Mar 4, 2023 at 1:12 PM
    #57
    Waasheem
    Waasheem
    2007 xrunner
    I agree with this. Mine rarely gets driven mon-fri, and on the weekends it's mostly short trips. I purposely stay in a lower gear for higher rpms to help get it warmed up which seems to help keep the white crud off the oil fill cap.
    Dm93[QUOTED] likes this.
  18. Mar 4, 2023 at 1:31 PM
    #58
    george3
    New Jersey
    So as long as I get to normal operating temperature I don't have to worry about milk - correct ?
  19. Mar 4, 2023 at 1:59 PM
    #59
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Everyone’s giving opinions here actually.
    Oil analysis does give you data, recommending doing that instead of changing oil more frequently is an opinion.
    Changing oil more frequently assures you of your oil being good and not much more costly than analysis, if any. Recommending that is also an opinion.
    I considered oil analysis but have decided to just go with the manuals recommended time interval of 1 year for my 3rd gen (normal driving, infrequent short trips since I worked from home and now retired). I formed my own opinion and it wins, as each of us are entitled to do lol.
    Dm93 likes this.
  20. Mar 4, 2023 at 2:07 PM
    #60
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You may still get a bit of cream under the oil cap in very cold ambient temps but moisture buildup in the oil will be minimized whe you get the engine up to temp and maintain it for a period of time regularly.
