retorque propeller shaft bolt
Discussion in 'Technical Chat' started by chriskingod, Aug 22, 2010.
  1. Aug 22, 2010 at 4:11 PM
    chriskingod
    chriskingod [OP] New Member
    PreRunner SR5
    The required maintenance for my 2010 Tacoma calls for a retorque of the propeller shaft every 15k miles. I assume this means the drive shaft. As I look at it, there are only two sets of bolts, one where it connects to the differential and the other is a mounting bracket where the 2 sections join. Which bolts are the ones requiring retorquing and what is the desired torque? Thanks
  2. Aug 22, 2010 at 4:32 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Please!!!!
    Take care
    vbibi:(
  3. Aug 22, 2010 at 4:42 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    Nah, I wouldn't even worrie about it. I have had my truck for 5 years and never fooled with that.
  4. Aug 25, 2010 at 5:35 AM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    Set the torque wrench to ~80% of the recommended torque and apply to each bolt. If the torque wrench clicks and a bolt doesn't move you're okay. If the bolt turns at 80% before clicking, then loosen all the associated bolts and re-torque. You might be okay to re-torque the loose one but doing the associated ones too will ensure complete & even seating.
  5. Aug 25, 2010 at 6:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's referring to the 4 bolts that hold the shaft to the rear diff. The torque spec is 88Nm (65 ft/lbs).
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/035001.pdf
  6. Aug 25, 2010 at 5:36 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  7. Nov 6, 2010 at 5:49 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    Is is necessary to loosen the drive shaft bolts, or just make sure that they are torqued to proper specs?
  8. Nov 8, 2010 at 11:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Just make sure they are torqued to the proper spec.
  9. Nov 14, 2010 at 2:17 PM
    JKD
    JKD Well-Known Member
    Hmm...my set of fairly cheap crow foot adapters won't torque these bolts. They slip before I ever get to 60 ft-lbs. Like, slip off the corners of the nut -- it even rounded a corner of the nut a bit, which is when I gave up.
    Do I just need a better clawfoot wrench, or is there a better tool for this? I'm thinking of getting one of my students who are taking welding to cut a cheap 14mm box-end and weld on a 1/2" square hole for a torque wrench.
