Retorquing Suspension Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, May 10, 2021.
  1. May 10, 2021 at 2:18 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    I replaced my front coils & shocks, LBJ's, rear leaf springs, and rear shocks around September 2019. I had torqued everything to spec and used Loctite Blue 242 as well to the bolts that needed it. I also retorqued the bolts a few weeks after I had installed everything to make sure nothing had moved prior to a trip.
    I had some maintenance planned for this summer, and I wanted to see what others opinions were checking the torque on suspension components? I wasn't sure if it was overkill, or an overlooked part of yearly maintenance.
    Thanks,
    Tom
  2. May 10, 2021 at 4:12 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    MalinoisDad and Abeyancer like this.
  3. May 10, 2021 at 4:22 PM
    Tjsingle26
    Tom
    PA
    Sold. I am definitely going to do this, Thank you!
  4. May 10, 2021 at 4:36 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    It can't hurt.
    The paint is a great idea.
    I had an alignment shop fail to torque my cam alignment bolts. One of them came off way down in Baja 700 miles from the nearest toyota dealer where I could get a new alignment cam bolt. I found a bolt at a hardware store down there to get me home but my alignment was super super bad.
    Had I double checked the alignment shops work and done a better daily inspection (like I do on trips after that) I would have caught it well before it got that bad.
