Retread Opinions
Discussion in 'Wheels & Tires' started by badguybuster, Mar 14, 2009.
  1. Mar 14, 2009 at 7:00 AM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I found a SMOKIN' set of Maxxis Mudder tires locally for sale. However, they are retreads but still...only $300 for the set of 4. They are "New" retreads, I guess that is kind of an odd phrase. Anyways, what do ya'll think??
  2. Mar 14, 2009 at 7:31 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    go 4 it
    retreads are the exact same as a new tire except there used (if that makes sence)
  3. Mar 14, 2009 at 7:32 AM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I say go for it. Just try to get some sort of warranty on them if possible.
  4. Mar 14, 2009 at 8:43 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    from a truck driver stand point
    Keep a close eye on tire pressure if the get low like any tire will over heat but unlike a new tire can let go a little easier.
    If the place that did them nows what they are doing should last until you have no more tread.
    If you are going to use them on a second pair of rims just for mudding then go for it.
  5. Mar 14, 2009 at 9:12 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Typically retreads are used only on the rears. I like virgin rubber up front.
  6. Mar 14, 2009 at 11:46 AM
    badguybuster
    Michael
    Here is something else a little weird. First, this truck had about 12,000 miles on it when I bought it and this is the first time I have had to buy tires for it. I was looking at the info sheet and it says it should have 265/65/R16, o.k.? No big deal. It has the factory rims on it BUT the tires it has on are 265/65/R17. So, am I to assume the original owner put bigger rims on it? They are the factory style. I am puzzled.
  7. Mar 14, 2009 at 12:28 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    he put 17 inch factroy wheels on a truck that came with 16 inch wheels
  8. Mar 14, 2009 at 4:44 PM
    badguybuster
    Michael
    It would seem so.
  9. Mar 14, 2009 at 5:17 PM
    badguybuster
    Michael
    Now I am a bit concerned about buying tires. The tires that are on it now are touring tires but I am going to a more rugged tread, there is plenty of clearance but I still worry about them rubbing on the inside of the fender well.
