Retro fit auto LSD??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kaybat, Oct 25, 2008.
  1. Oct 25, 2008 at 11:53 AM
    Kaybat
    Kaybat [OP] Member
    Central Fla
    08' SR5 4X4
    tow pkg,homelink mirror,k&n air,cargo divider,all weather mats
    Newbie here....love my new 08 Taco....can't stand the open differential !!!:mad:
    driving around in rain is ridiculous, tires break loose at every light(not a lead foot either)....
    Is there a way to retrofit the (brake actuated)auto lsd on my ride?? I know the 09's come standard with it......If not,any other options?(besides selling the damn thing and getting hosed:()
    Fyi:don't do alot of off-roading(mainly tow my boat)....Thanks
  2. Oct 25, 2008 at 11:57 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'd rather have the mechanical lsd over the auto lsd. i had the mech lsd on my 07 prerunner sport
  3. Oct 25, 2008 at 11:58 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    may i ask if some weight on the bed could help solve that?? i was wondering the other day..
  4. Oct 25, 2008 at 12:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What tire pressure you run at?
    I have the mechanical LSD and my tires break-loose when the roads are slightly wet ...In fact, It did it today (34psi in tires).
    That's the whole deal with having a pickup truck. The rear-ends are soooo damn light weight, doesn't take much to break'em loose. Lower tire pressure might help keep the tires on the road.
    I'm not sure the Auto LSD is gonna help you .... if both tires are cutting loose - the brakes probably won't intervene. The auto-LSD works when one of the tires is spinning while the other one isn't.
  5. Oct 25, 2008 at 2:05 PM
    Kaybat
    Kaybat [OP] Member
    Central Fla
    08' SR5 4X4
    only one side breaks loose....and they are at full pressure....maybe let a few pound out??
    this is my 1st truck(last ride was an suv)....
  6. Oct 25, 2008 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do a search for Detroit Tru Track. Its one of the best LS on the market, and less expensive than anything Toyota offers.
  7. Oct 26, 2008 at 4:07 AM
    Janster
    Jandy
    Lancaster, PA
    You could try letting some pressure out of the tires and/or adding weight in the bed. However - lowering tire pressure and adding weight to the bed will suck up a little bit more gas.
    That's something pickup trucks are known for - with vitually no weight in the bed (compared to anything else). It's definately something to get used to if you've never had a truck before. When its raining, you just gotta give yourself more room (at an intersection) to get out into traffic and use a lighter gas.
  8. Oct 26, 2008 at 11:55 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I'm running about 34psi allterrains i was hauling wood last week and the tire would still break loose its really the only thing that makes me think i should have gotten the more expensive sport.
  9. Oct 26, 2008 at 2:13 PM
    Janster
    Jandy
    Lancaster, PA
    The Sport version isn't really gonna help ya either. I have the Sport (Access cab).
    I doubt there'd be much difference in a Sport Double cab....(in terms of more weight near the rear-end). But - I dunno..??
  10. Oct 28, 2008 at 8:55 AM
    bajataco05
    bajataco05 ASE certified
    south carolina
    05 PreRunnerSR5 access cab, TRD sport, 6 spd.
    functional hood scoop, ram air induction (in the works), short throw shifter, cherry bomb catback exhaust, and indash dvd/nav sys.
    Trucks are very light in the rear and consequently they dont get very good traction. my 05 TRD acces cab with Lsd doesnt hook up in the rain ether. the only thing you can try is like the other guys said, add weight to the rear and put your tires at 32 psi. Off road tires arnt designed for maximum traction on the road so you could use a softer more streetable tire but then that changes the look your after. I would just say its something you have to get used to!
  11. Oct 28, 2008 at 10:18 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    yeah man you really will get used to it after a while I have been around trucks most of my life. I went a few years with only cars and just got my toyota a few months ago. Mine is the off road package so the locking dif doesn't do me any good when I'm on the streets in the rain. But being used to trucks I haven't had any difficulty keeping my tires firm on the ground. Its not even something I think about when its raining. give it a little while and you will see.
