Retro fit source kits. Any good? Which kit to buy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 552Jrider, May 9, 2012.
  1. May 9, 2012 at 9:31 AM
    552Jrider
    552Jrider [OP] Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Was wonering if anyone has used any of the retro fit source kits. If so which one did you use? And If you have any pics so i can see what they look like in a first gen. Thanks
  2. May 9, 2012 at 9:46 AM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    I have no personal experience, but have seen a few. They look good. Heard great things about their customer service. I plan on getting the FXR's or Morimoto Minis and doing the conversion. There are a few write ups on here...sorry can't link from my phone.
  3. May 9, 2012 at 2:15 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have the morimoto mini h1 kit. Awesome light output, cheap and easy to install. As mentioned, TRS has awesome customer service too
  4. May 9, 2012 at 4:04 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    does that kit come with everything needed?
  5. May 9, 2012 at 5:09 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    It does. Only thing I added extra was re-sealing glue for the lights, which isnt 100% needed.
    The kit had everything.
  6. May 9, 2012 at 8:54 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    k. which bulb would you recommend. ive read that some people like the 4300 and some like the 5000
  7. May 10, 2012 at 7:57 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I have the mini h1's with 5k bulbs and I love them.
  8. May 10, 2012 at 1:07 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    K thanks for all the help. Think im gonna get some stuff ordered soon and get it done. My stock lights suck
  9. May 10, 2012 at 2:35 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    4300k is what all OEMs use. It has the most useable light and will give the best lighting possible. 5000k is slightly blue, which looks "cool" to some people, but it produces less lumens (less bright). 6000k-8000k is pretty blue, and less lumens as you go higher. Any higher Kelvin the color chart goes a bit wild with purples, pinks, greens, etc. Lower than 4300k goes more yellow like your classic halogen bulb.
    I have the H1 4300k because I personally care for function over form.
    The Morimoto minis only have two bulb options H1 and DS2. Both are great and both have their strengths and weaknesses but you cant really go wrong with either.
  10. May 28, 2012 at 2:47 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Got it done. I love the halos
  11. Sep 13, 2012 at 8:22 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod, Kobalt tool box, Bulldog Keyless entry, Sportsman max-4 seat covers, modded EL Bazooka basstube, Friends of Coal sticker and license plate, Green Hooks, Green Emblems, Green LED sony radio, Green shiftknob.
  12. Nov 15, 2012 at 3:05 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    my roommate has a 99 and he just picked up some fleabay clear headlight housings for pretty cheap and did a retro in that. turned out pretty well!
