Retro-Solutions Bi-Xenon HID Kit - AWESOME
Discussion in '1st Gen. Tacomas (1995-2004)' started by NYProud, Nov 13, 2009.
  1. Nov 13, 2009 at 9:40 AM
    NYProud
    NYProud [OP] Active Member
    Chief
    OKC, OK
    98 Tacoma Ext Cab SR5 4x4 TRD
    CATZ Hyper White Fog Lamps in Front Bumper, LowRider Hard Shell Bed Cover
    Just wanted to let all my fellow 1st Gen Tacoma owners know that I just installed a Bi-Xenon HID conversion kit (Low and High Beams) in my '98 Tacoma X-tra cab 4x4 TRD, and they are unbelievably great! I bought the 8000K (slightly blue-white), and the difference between the HIDs and my original Halogen (Star-Brites) is overwhelming...super bright white like monster fluorescents...light up the night, and reflective signs like an alien space craft (in movies). Not expensive...great quality components...3000 hr bulb life, all for less than $200. Great customer service...U.S. Company (CT).
    Check it out: www.retro-solutions.com
    Good luck...Chief
  2. Feb 14, 2010 at 10:07 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    did you do a projector retrofit or just plug-and-play? how's the light cut-off (if you went with the plug-and-play kit)?
  3. Feb 14, 2010 at 10:28 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
  4. Feb 15, 2010 at 6:54 AM
    NYProud
    Chief
    OKC, OK
    To reply to your question, I went with plug and play...and it really is that simple. Wiring harness plugs up to one (left) headlight connector, power connection to battery, and then plug ups to digital ballast units (one on each side of the engine bay). Everything fits perfectly to stock headlight units. And, the light output is AMAZING! Low beams are like super bright blue-white beams (8000k set) of fluorescent light - like daylight on OK rural roads. High beams are fully un-shielded filament beams that almost double the beam range...but really not needed on even the darkest roads...also great on foggy nights/mornings.
    Hope that answers your question. I've had them on my 98 Taco 4x4 TRD now for about 4 months - in all the miserable snowy, icy winter weather here, and I'm blown away. Also, I recently added clear front lenses and replaced most of my regular (incandescent) bulbs with LEDs (all but back-ups) from LEDs bought on E-Bay (cheap!) and they + the HIVs make my Taco look like a freakin' spaceship! AWESOME!
    Good Luck....Chief ;)
  5. Feb 15, 2010 at 8:46 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    hey chief,
    thanks for the reply! it does sound pretty simple! do you happen to have any pics showing the down-the-road view? that would help a lot! thanks! :)
  6. Feb 15, 2010 at 1:23 PM
    NYProud
    Chief
    OKC, OK
    No...no pix of beams on the road but trust me, for less than $200 (from Retro Solutions) and about an hour's worth of work, you'll enjoy the difference in night driving. And, I expected to get flashed by on-coming drivers because of the HID brightness and range but so far NOTHING. I adjusted my headlight beams just a hair low, and both beams almost dead center straight ahead, and still they light up both sides of the street :) The Xenon bulbs are warranted for 10,000 hours, but just in-case I bought an extra set of bulbs ($80). I'm good to go for YEARS! :)
  7. Feb 15, 2010 at 1:28 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    might wanna get that checked out :D
  8. Feb 15, 2010 at 1:45 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    thanks for the insight! i'll definitely be looking into it. a couple months ago, i upgraded the stock bulbs to phillips xtravision (or something like that)... they're noticeably whiter and a little brighter, but nothing compared to HID... which is my goal.
    anyways, thanks much for your help!
