Retrofit causing relay to go bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by T3XASMAD3, Apr 6, 2013.
  1. Apr 6, 2013 at 9:48 PM
    T3XASMAD3
    T3XASMAD3 [OP] Member
    Ty
    Waco, Texas
    01 SR5 PreRunner
    I did a retrofit on my 01 taco about 10 months ago and havent had any trouble with it. The other day my tail lights and dash lights stopped working when i was driving so i checked the fuse and it was blown. Put a new fuse in and it did the same thing. I got to thinking it was the relay so i took it to the shop and it was in fact the relay. The guy that worked on it then told me that those "blue lights" were what caused the relay to go bad. So then today it happened again. Same exact problem. Anyone have any ideas?
  2. Apr 7, 2013 at 7:54 AM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Possibly a short somewhere? Check the wiring with the headlights if you believe that is what is causing it. I couldn't imagine the headlight wiring would interfere with the tail wiring, but, then again, I don't know how Toyota set it up..
  3. Apr 7, 2013 at 7:57 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not completely sure on 1st Gens but typically the headlights are on a separate fuse than the tail and marker lights. I'm guessing you have a chaffed wire somewhere causing a short. When the fuse blows, do your headlights still work?
    If your retros were connected correctly, there should be very little draw from the factory wiring. Retros pull their power from another wire and only use the factory wiring as a switch.
  4. Apr 7, 2013 at 8:02 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I would try putting in a higher rated fuse. If it's a 10 amp fuse, try putting in a 20 amp fuse and see if it still blows.
  5. Apr 10, 2013 at 4:03 PM
    T3XASMAD3
    Ty
    Waco, Texas
    01 SR5 PreRunner
    sorry for the long delay, when the fuse blows the headlights remain on. Also i have tried going up to a bigger fuse and no luck. Ive checked the all the wiring and have had no luck... any other suggestions?
