Retrofit Headlight Washer Jet on Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BountyOR_VF2, May 9, 2019.
  1. May 9, 2019 at 3:40 PM
    BountyOR_VF2
    BountyOR_VF2 [OP] "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    Hello TW, I just did this mod lately and I like it a lot. Some people might not agree on the way it looks but hey that’s just me, I like the OG style Offroad truck from the ’80s and ’90s that has a Headlamp washer.
    The old school LC80 and Mitsubishi Pajero/Montero or even the Land Rover has this headlamp washer as a standard feature, and nowadays if you getting a high-end Lexus LX, GX or LC200 you can still have this feature comes with the truck. So why not put this back to our Tacoma?
    Here’s the list of materials I bought. if you find something better then it is great.
    Headlamp Headlight Washer Jet Sprayer Nozzle Pair Fit for Land Rover LR2 08-13
    https://www.ebay.com/itm/Headlamp-H...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    New Pair Headlamp Washer Nozzle Clip Fits Land Rover LR2 LR3 LR4 2.0L 3.0L
    https://www.ebay.com/itm/New-Pair-H...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    6mm Windshield Washer Fluid Hose Tube Repair Kit, includes 2 pieces of 59" hose
    https://www.ebay.com/itm/6mm-Windsh...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    OTUAYAUTO Wiper Washer Windshield Check Valve - for Toyota, Scion, Lexus - Replaces OEM #: 85321-28020, Spray Jet Kit (pack of 2)
    https://www.amazon.com/gp/product/B07PWZFP6F/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    TOYOTA OEM Wiper Washer-Windshield-Washer Hose Y-connector 8534814390
    https://www.ebay.com/itm/TOYOTA-OEM...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    1. Cut the hold with a Step drill bit that fit perfect for the Washer jet fixture, you can choose the one I use, or you can buy something else and maybe more creative.
    2. Remove the two 10 mm bolts that hold the Washer Fluid tank.
    3. Carefully pull tank up until you can see the washer pump at the bottom of the tank. Disconnect the 2 pins connector.
    4. Pull the entire Washer fluid tank up, let it sit on top of the air intake. (I recommend you guys empty the washer fluid tank first, that way it is much easier and less messy with water spread everywhere.
    5. Pull the factory 6 mm washer hose out from the pump.
    6. Cut a 12” 6 mm washer hose you bought from Amazon or eBay, insert that to the water pump outlet.
    7. Connecting the hose with the Toyota Y-connector 8534814390, insert the factory hose to the hood, and insert another precut 6mm hose to another Y connector.
    8. Insert precut 6mm hose to the Y connector, and to the Headlight washer fixture *That Land rover fixture is about 8mm, but it will fit with the 6mm hose.
    9. Insert another 59” (Full length) hose to the driver side of the headlight washer fixture.
    10. Secure all the necessary hardware for your washer jet, in my case, it is the Washer nozzle clip right underneath the bumper skin.
    11. Reconnecting everything back to the washer fluid tank, and the two pins connector.
    12. Fill the tank with water, test it, and here you have a perfect headlight washer for your truck, and now get ready for mud!
    (Note) Since the washer fluid tank pump is always open, it is required to have a check valve install for the hose below the water level, otherwise, it will empty the tank overnight.
    https://www.instagram.com/p/BxMHmwJBFdZ/?utm_source=ig_web_copy_link
  2. May 9, 2019 at 4:20 PM
    caribe makaira
    Caribbean, Puerto Rico
    Now get the Canadian version of the washer tank, it has the fluid level sensor so ya don't run out...
  3. May 9, 2019 at 5:31 PM
    BountyOR_VF2
    NorCal Bay Area
    No wonder I saw an extra connector on the washer tank hardness! Now that make perfect sense! Thanks for the suggestion!
  4. May 9, 2019 at 5:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nicely done! That is sharp.
    Headlight washers are required by law on all vehicles equipped with HIDs, as dirt on the lens causes scatter and glare from the high intensity light source.
  5. May 9, 2019 at 5:46 PM
    caribe makaira
  6. May 9, 2019 at 5:59 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Nice mod. Thanks
    BountyOR_VF2[OP] likes this.
  7. May 9, 2019 at 5:59 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I think it is for ECE, Not US DOT though.
    Cool mod!
  8. May 9, 2019 at 6:00 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Is it? Admittedly I haven’t paid close attention on that one.
  9. May 9, 2019 at 6:10 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Cool mod OP! Original too.
    OA
  10. May 9, 2019 at 6:12 PM
    hyper15125
    NJ (609)
    Last I read unless it changed for the US.
    crashnburn80[QUOTED] likes this.
  11. May 9, 2019 at 6:13 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    well well looks like this would be a nice 2nd gen mod too.
  12. May 9, 2019 at 6:15 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    No they are not. Any headlight regardless of bulb type that’s over 2000 lumens (on low beam only) is required to have them for ECE approval. North American DOT approval has no such mandate of washers under any circumstances.
    Silentshredr likes this.
  13. May 9, 2019 at 6:15 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    That's pretty neat op. Nice work and clean install
    VE7OSR and BountyOR_VF2[OP] like this.
  14. May 9, 2019 at 6:16 PM
    nudavinci64
    Robert
    how fast did it take to get the washer since they seller is in china?
  15. May 9, 2019 at 6:17 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    These are required in Europe. They look great by the way , nice install.
  16. May 9, 2019 at 6:20 PM
    BountyOR_VF2
    NorCal Bay Area
    I actually ordered it Monday, received Thursday. And shipment was from Ohio, the washer itself are made in United Kingdom!
  17. May 9, 2019 at 6:21 PM
    nudavinci64
    Robert
    gotcha the one linked says it comes from China. Did you order it from another spot?
    Also for the check valve its open but it runs to each washer did you have issues with it leaking? Curious how they manage that on other vehicles. I assume you leave it off unless you need it.
  18. May 9, 2019 at 6:38 PM
    BountyOR_VF2
    NorCal Bay Area
    I think they have multiple shippers in US, just like Amazon you know. But that's the link I ordered the washer.
    Yes, you are correct, that's the reason why I'm using two Y connector, one is the Y splitter, and the other is the one-way check valve Y connector to prevent leakage.
    $12 OTUAYAUTO Wiper Washer Windshield Check Valve - for Toyota, Scion, Lexus - Replaces OEM #: 85321-28020, Spray Jet Kit (pack of 2)
    $5 TOYOTA OEM Wiper Washer-Windshield-Washer Hose Y-connector 8534814390
    eurowner likes this.
  19. May 9, 2019 at 6:42 PM
    nudavinci64
    Robert
    Totally I saw other vendors most were in China, you just never know sometimes on Ebay yah know? I completely missed that other splitters were a one way check valve. :crazy:
  20. May 9, 2019 at 10:26 PM
    caribe makaira
    Can you show a picture of how it looks from behind/underneath where the clips hold the nozzles?
    BountyOR_VF2[OP] and nudavinci64 like this.
