Retrofit Headlights Group Buy 05-15
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by kustom54lighting, Jan 29, 2021.
  1. Jan 29, 2021 at 10:07 PM
    kustom54lighting
    kustom54lighting [OP] Well-Known Member Vendor
    So we have interest in our GB products and decided to do a group buy. This group buy doesnt have as many options as our custom ordered retrofits but are cheaper but also will take longer to build. There is no substitutions for the options which is why they are cheaper. Please read the following changes to our retrofits and why our builds will take 8-12 weeks to ship.
    As of 2019 we are the only retrofit company to adapt free lens clear coating for any set that leaves our shop, no exceptions. Why did we do this? UV rays damage lenses plain and simple OEM or Aftermarket, and our company wanted to fix that due to our own standards and because frankly our lights cost a lot of money and should not fade even if nature is causing the issue. We also discovered while we do a clear coat process we can also at the same time test for any seal imperfections and have been able to guarantee a 99% perfect lens to base seal. Currently since we have started this process we have had ZERO lens yellowing or peeling issues and less than 2% moisture issues. The 2% also keep in mind is due to drastic temp changes and went away soon as the lights had time to vent and none of them had to get sent to us to get resealed.
    Care for the lenses requires no more then the care for your vehicles paint job. We use 4 coats for automotive clear coat (not rattle can). Your lenses after 60 days of receiving your lights will be able to get waxed, clay bar, and sealed with your choice of products. If your a hard core off roader what does that mean for you? well if you ever scratch the lenses you can actually wet sand and buff your lenses to look like new (to an extent of course of your abilities)
    **CLIENTS WITH ALL TIME DRL**
    If your vehicle comes with all time on DRL in 05-15 model please keep in mind factory bulbs will damage the lenses internally as I'm sure you have noticed on your OEM lights, and same thing will happen in retrofits. This is due to how hot the DRL bulbs gets which we tested and got them up to 220 degrees in 5 minutes. The bulbs heat just bakes the lenses from the inside and we will not warranty that. There is a solution though, you can disable your DRL if your vehicle allows or add LED DRL/Blinker bulbs. Again this is only for people that have they DRL/Blinker bulb on all the time no matter what position your multi function switch is on.
    05-11 Retrofits full plug and play starting $585 shipped WITHOUT HID KIT, HID kit required with H1(for H1 projectors) or D2S or D2H bulbs (for D2S projectors)
    https://kustom54lighting.com/05-11-Toyota-Tacoma-Retrofit-GROUP-BUY_p_472.html
    12-15 Retrofits full plug and play starting at $655 shipped WITHOUT HID KIT, HID kit required with H1(for H1 projectors) or D2S or D2H bulbs (for D2S projectors)
    https://kustom54lighting.com/12-15-Toyota-Tacoma-Retrofit-GROUP-BUY_p_471.html
    Options for projectors and paint have been discounted paired with a free HID Kit. Additional Group Buy discount code automatically applies at check out
    Install instructions
    https://www.tacomaworld.com/threads...yes-halos-install.490836/page-4#post-17122514
    Options
    http://kustom54lighting.com/FAQ_c_44.html
  2. Jan 30, 2021 at 6:17 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    How long are you keeping this group buy going? Curious to know for budget reasons.
  3. Jan 30, 2021 at 6:22 AM
    stimey
    stimey Well-Known Member
    nova
    tacoma t|x pro
    So tempting ... how long until group buy closes?
  4. Jan 30, 2021 at 6:56 AM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Don't hesitate! They do some great work. Love how mine turned out. :thumbsup:
  5. Jan 30, 2021 at 9:33 AM
    outershell
    outershell Well-Known Member
    Kyle
    2006 Tacoma TRD OR 4x4
    Love mine! So bright with a sharp cutoff, or blast the road with high beams.
    I have the D2S 5.0 bixenon and didn't wire in the shrouds for a super stock look.
  6. Jan 30, 2021 at 9:54 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
  7. Jan 30, 2021 at 10:27 AM
    kustom54lighting
    thanks for the kinda words!
  8. Jan 30, 2021 at 10:27 AM
    kustom54lighting
    2 weeks probably
  9. Jan 30, 2021 at 10:28 AM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Looks like great quality work how long will this gb be active.
  10. Jan 30, 2021 at 10:29 AM
    brian.gonz
    Brian
    Manor, Texas
    Nevermind just got my answer
  11. Jan 30, 2021 at 10:30 AM
    kustom54lighting
    Hehe no problem our fault, we should of posted that In the main post
  12. Jan 30, 2021 at 10:32 AM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    +1 interested in this group buy
    kustom54lighting[OP] likes this.
  13. Feb 1, 2021 at 3:35 PM
    fr0stbytten
    fr0stbytten Well-Known Member
    Can we get the Panamera shrouds blacked-out along with the housing?
    Do y'all do the wiring for the Panamera DRL?
  14. Feb 1, 2021 at 4:06 PM
    kustom54lighting
    That’s something we do by default if you pick the paint option if you pick chrome then in comments you have to specific my. The wiring comes with little taps that you run to your truck wiring
  15. Feb 1, 2021 at 4:15 PM
    fr0stbytten
    Awesome!
    What kind of DRL/Blinker bulb do y'all recommend?
  16. Feb 1, 2021 at 4:35 PM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    SoCal
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Iv been using triton V6 for about two years with no problems. 3AE14437-F27A-42A7-A974-37219E1E26AF.jpg3055666E-D2DA-4782-B1C1-FA1BC740A939.jpg
  17. Feb 1, 2021 at 5:20 PM
    kustom54lighting
    Honestly I’d buy something with good reviews on Amazon and make sure to get resisters with it. I don’t believe in spending a fortune on blinker bulbs hehe
    fr0stbytten[QUOTED] likes this.
  18. Feb 1, 2021 at 6:24 PM
    kustom54lighting
    I’m sure our clients can post output pics
  19. Feb 1, 2021 at 7:18 PM
    gnardoggie
    gnardoggie Well-Known Member
    Am I able to forego the HID kit to lower the price if I have bulbs/ballast already?
  20. Feb 1, 2021 at 8:05 PM
    kustom54lighting
    Only if you have ballasts, harness and H1 or d2s bulbs. Regardless yes I can discount the price depending on which parts you don’t need
