Retrofit Headlights Group Buy 05-15
Discussion in 'Lighting' started by kustom54lighting, Jan 29, 2021.
  1. Jan 29, 2021 at 10:09 PM
    kustom54lighting
    kustom54lighting [OP] Well-Known Member Vendor
    So we have interest in our GB products and decided to do a group buy. This group buy doesnt have as many options as our custom ordered retrofits but are cheaper but also will take longer to build. There is no substitutions for the options which is why they are cheaper. Please read the following changes to our retrofits and why our builds will take 8-12 weeks to ship.
    As of 2019 we are the only retrofit company to adapt free lens clear coating for any set that leaves our shop, no exceptions. Why did we do this? UV rays damage lenses plain and simple OEM or Aftermarket, and our company wanted to fix that due to our own standards and because frankly our lights cost a lot of money and should not fade even if nature is causing the issue. We also discovered while we do a clear coat process we can also at the same time test for any seal imperfections and have been able to guarantee a 99% perfect lens to base seal. Currently since we have started this process we have had ZERO lens yellowing or peeling issues and less than 2% moisture issues. The 2% also keep in mind is due to drastic temp changes and went away soon as the lights had time to vent and none of them had to get sent to us to get resealed.
    Care for the lenses requires no more then the care for your vehicles paint job. We use 4 coats for automotive clear coat (not rattle can). Your lenses after 60 days of receiving your lights will be able to get waxed, clay bar, and sealed with your choice of products. If your a hard core off roader what does that mean for you? well if you ever scratch the lenses you can actually wet sand and buff your lenses to look like new (to an extent of course of your abilities)
    **CLIENTS WITH ALL TIME DRL**
    If your vehicle comes with all time on DRL in 05-15 model please keep in mind factory bulbs will damage the lenses internally as I'm sure you have noticed on your OEM lights, and same thing will happen in retrofits. This is due to how hot the DRL bulbs gets which we tested and got them up to 220 degrees in 5 minutes. The bulbs heat just bakes the lenses from the inside and we will not warranty that. There is a solution though, you can disable your DRL if your vehicle allows or add LED DRL/Blinker bulbs. Again this is only for people that have they DRL/Blinker bulb on all the time no matter what position your multi function switch is on.
    05-11 Retrofits full plug and play starting $665 shipped
    https://kustom54lighting.com/05-11-Toyota-Tacoma-Retrofit-GROUP-BUY_p_472.html
    12-15 Retrofits full plug and play starting at $735 shipped
    https://kustom54lighting.com/12-15-Toyota-Tacoma-Retrofit-GROUP-BUY_p_471.html
    Options for projectors and paint have been discounted paired with a free HID Kit. Additional Group Buy discount code automatically applies at check out
    Install instructions
    https://www.tacomaworld.com/threads...yes-halos-install.490836/page-4#post-17122514
    Options
    http://kustom54lighting.com/FAQ_c_44.html
    JoeTacoma02 likes this.
  2. Jan 29, 2021 at 10:20 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Awesome, placing order :thumbsup:
    :bananadance:
  3. Jan 29, 2021 at 10:27 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Curious what shipping would be to Hawaii! Zip code 96753
  4. Jan 29, 2021 at 10:32 PM
    kustom54lighting
    It’s free
    Amo-cat3[QUOTED] likes this.
  5. Jan 29, 2021 at 10:47 PM
    MickDog13
    MickDog13 Well-Known Member
    Cortland NY
    2008 Speedway Blue TRD OR DCSB
    After doing this mod myself diy and seeing just a few examples of ops work, I have to say his price is an obscene value.
    If I was doing this over, I’d pay this guy to do it.
    Also, bonus points for a true upgrade in your lights without blinding every single person coming your way.
    kustom54lighting[OP] likes this.
  6. Jan 29, 2021 at 10:48 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    That's a beautifull thing!! What about if I custom built one on your website? I'm sold on your clear coat and sealing process.
  7. Jan 29, 2021 at 11:00 PM
    kustom54lighting
    Our entire site is free shipping and Tacomaworld get 10 percent off custom sets too
  8. Jan 29, 2021 at 11:04 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    10% off too, I'm on it! I bought the Tacoma Beast headlights over a year ago and very very disapointed in it's light output. Can't take it no more lol.
  9. Jan 29, 2021 at 11:06 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Does the panamera shroud with switchback already have halos or can I do front and back switch back halos with the switchback panamera?
  10. Jan 29, 2021 at 11:11 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Hi, I'm interested, but I have a question. Do you use Toyota OEM housings or are they aftermarket?
  11. Jan 29, 2021 at 11:17 PM
    kustom54lighting
    Yes they already have it
  12. Jan 29, 2021 at 11:18 PM
    kustom54lighting
    Aftermarket but best brand which is TYC and clear coat addition makes them more resistant them OEM
    ppham444[QUOTED] likes this.
  13. Jan 29, 2021 at 11:19 PM
    kustom54lighting
    Msg me when your about to place and order I’ll get you a code
  14. Jan 29, 2021 at 11:21 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Thank you, I'm trying to decide on the shroud - decisions, decisons.............
  15. Jan 30, 2021 at 6:19 AM
    jarett92
    jarett92 Well-Known Member
    Jarett
    Raleigh, NC
    Do you have any pictures of the different reflector options with black housings (standard, paint to match, and tinted)? Having a hard time deciding.
  16. Jan 30, 2021 at 9:02 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    So I like the panamera shroud and I like front and back halos. Is the panamera switchback a single halo that does the switchback or can I do the panameras with front and back switchback halos?
  17. Jan 31, 2021 at 5:55 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I put an order in but just had a thought: do the projectors come with bulbs or do i need to choose an HID kit to go along with them? If so, I need to add an HID kit to my order.
  18. Feb 1, 2021 at 1:40 PM
    kustom54lighting
    Hey did you email us today about the questions you have?
  19. Feb 1, 2021 at 1:41 PM
    kustom54lighting
    we might in our gallery but paint to match and tinted almost same thing because tinted is so dark I would do smoked or clear if you actually want to see it stand out
  20. Feb 1, 2021 at 1:52 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    yes, that was me.
