Retrofit help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kcross33, Oct 22, 2017.
  1. Oct 22, 2017 at 1:03 PM
    Kcross33
    Kcross33 [OP] Well-Known Member
    Kade
    Fresno, Ca
    2006 TRD Off Road prerunner
    So I built a pair of retrofit headlights back in March, they have worked great, besides one of the morimoto switchback ring acting up every once in awhile (figured it was just a loose connection). But the other night both my hid headlight and halo went out on the same side. I was checking all my connections today and the halo was coming on and off but wasn't nearly as bright as the other side, then it went out completely. Anyone know why this would happen?
  2. Oct 22, 2017 at 1:13 PM
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    my money is on the ground... try removing the ground wire, roughing the body surface with sand paper and reinstalling.
    DriftingPanda18 and memario1214 like this.
  3. Oct 22, 2017 at 5:56 PM
    Kcross33
    Kade
    Fresno, Ca
    That was it! Thanks man!!!
  4. Oct 22, 2017 at 7:51 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
  5. Oct 26, 2017 at 4:57 PM
    DriftingPanda18
    DriftingPanda18 Well-Known Member
    Patel
    Florida
    2013 Spruce Green Prerunner
    33s
    How did you wire your switchback halos? I'm also about to do a retrofit this weekend.
  6. Oct 26, 2017 at 6:30 PM
    Kcross33
    Kade
    Fresno, Ca
    I just tapped them into the running lights and blinker and the ground to a bolt that I put into an empty hole to hold the ballast for the hids.
  7. Oct 26, 2017 at 7:44 PM
    DriftingPanda18
    Patel
    Florida
    33s
    Alright so you didn't have to tap into the ignition?
  8. Oct 26, 2017 at 7:47 PM
    Kcross33
    Kade
    Fresno, Ca
    No just have to flip your light switch to running lights to turn them on
    DriftingPanda18 likes this.
  9. Oct 26, 2017 at 7:48 PM
    DriftingPanda18
    Patel
    Florida
    33s
    Alright appreciate the help man!
  10. Oct 26, 2017 at 7:51 PM
    Kcross33
    Kade
    Fresno, Ca
    No problem dude, good luck on your build!
