Retrofit Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gavingamer901, Jul 12, 2022.
  1. Jul 12, 2022 at 4:00 AM
    Gavingamer901
    Gavingamer901 [OP] Well-Known Member
    Gavin
    Grand Rapids
    02 Double Cab TRD PreRunner V6
    4X4 conversion, 2" Lift, 1-Piece Aluminum Driveshaft, 265/75/r16 Tires
    So I’m doing a projector retrofit, and idk if I’m just dumb but I can’t get this stupid rubber seal broken (between lens’s and housing). I’ve been preheating to 270 for 7 mins but I can’t get it and now I just chipped the housing ;-;. Any advice? I read maybe upping temps to 350 might help but I don’t wanna risk chipping them again so I’m waiting till I post here. Thanks in advance!
  2. Jul 12, 2022 at 8:59 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I used a heat gun on mine. On both the oem and aftermarket housings.
    Be careful with the adjusters, oem is much better. I swapped mine to to aftermarket housings.
    Also good luck with wiring its kind of a pain, keeping the highbeam indicator will require a resistor on the high beam circuit.
    Gavingamer901[OP] likes this.
  3. Jul 12, 2022 at 11:17 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    You using oem or aftermarket housings? New or old? Sounds like you ended up with some that are permasealed and not sealed up with butyl. I'd stick to about 250° but go a little longer, ~12-14 minutes for the first round.
  4. Jul 13, 2022 at 2:53 PM
    Gavingamer901
    Gavin
    Grand Rapids
    I’m using some aftermarket ones I bought for cheap. At this point I might just restore the OEM’s and do my retrofit in those. I went cheap and it showed Lol.
