Retrofit high beam in-op
Discussion in 'Lighting' started by EricU, Jun 5, 2015.
  1. Jun 5, 2015 at 4:24 PM
    EricU
    EricU [OP] Well-Known Member
    Englewood, CO
    I recently installed some mini H1's into my headlights, tested the high beam actuator 50+ times prior to installing them, worked flawlessly, today i noticed 1 high beam does not function. i checked the wiring and its all connected as it should be.
    Are there any quick fixes for this problem? I emailed TRS just a bit ago, but if theres a trick that gets them to work, id like to try while i wait to hear back from TRS
  2. Jun 6, 2015 at 8:19 PM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Are you sure you checked the ground for that particular side? A bad ground may look correct, but will prevent anything from working.
  3. Jun 7, 2015 at 6:57 AM
    EricU
    Englewood, CO
    Low beams work for both lights, all connections are tight and secured, grounds are all metal to metal. its just the one side that will not trigger the high beam cut off
  4. Jun 8, 2015 at 1:19 AM
    theblindchicken
    Christian
    Long Beach
    '74 K10
    Hmm... Do you have a multimeter? If so, I'd check to see if you have power going to the solenoid. It will help you determine whether the problem is before the solenoid or with it.
  5. Jun 8, 2015 at 4:46 PM
    EricU
    Englewood, CO
    yup i have a multimeter, TRS suggested i check the high beam connector to make sure its getting the correct voltage or any signal at all.
  6. Jun 8, 2015 at 7:06 PM
    theblindchicken
    Christian
    Long Beach
    '74 K10
    Exactly where I was thinking. If you do have voltage, just trace it on down the line or vice versa.
  7. Jun 8, 2015 at 7:09 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    What harness are you using? Maybe also check that the pins on the female side of the harness coming out of the headlight are both clicked into their correct positioning as well.
