Retrofit High Beams Don't Work
Discussion in 'Lighting' started by BakerTaco, Feb 27, 2014.
  1. Feb 27, 2014 at 1:21 PM
    Edpsx
    Edpsx Well-Known Member
    DFW
    13' Double Cab Limited MGM
    K&N Intake, Stainless Tube Steps, Pioneer 8500BHS, Coming Soon:, Morimoto H1 Mini, Viper 5704
    So the relays are clicking, is the light going out when you switch to high beam?
  2. Feb 27, 2014 at 1:31 PM
    BakerTaco
    BakerTaco [OP] Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Nevermind. Relays aren't clicking.. Something's clicking but they're still on low beams..
  3. Feb 27, 2014 at 2:14 PM
    Edpsx
    DFW
    Id say put 12v directly to the projector relay and see if they are functioning.
  4. Feb 27, 2014 at 6:22 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Ill try it but I haven't had time. I've been driving all day and I'm still driving. My high beam indicator is permanently on. Does that mean anything??
  5. Feb 27, 2014 at 6:28 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    I'm going to take a guess. Maybe the shield isn't going down?
  6. Feb 27, 2014 at 7:53 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Yeah. I'm aware. Thank you
  7. Feb 28, 2014 at 4:28 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Have you reconfigured the H4 connector yet?
  8. Feb 28, 2014 at 9:09 AM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Yeah. None of the configurations made a difference
  9. Feb 28, 2014 at 10:34 AM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Ok so I'm back at work on them. I just got the high beams to work. I flipped then on and off about 5 times, then they went back to not working...
  10. Feb 28, 2014 at 1:45 PM
    Edpsx
    DFW
    Maybe the harness is bad? How old is it?
  11. Feb 28, 2014 at 2:15 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Brand new... This is the first time I've used it.
  12. Feb 28, 2014 at 2:48 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    My first harness that I got with my retros would blow fuses when I hit the high beams. Turns out it was a defective control box/harness. Check the fuse for the highs and see if it's popped. It's a 5A fuse in the under hood fuse box. Other than that, I'd probably bet on a bad control box, meaning, shipping back the harness for a new one.
  13. Mar 3, 2014 at 3:44 PM
    OverPar
    OverPar Well-Known Member
    Dirt Guy
    NW CT
    09 TRD Sport
    Fold-a-Cover G4 Elite, Light bar (X3 Hella), Thule/OEM RR, Avid OR BO Sliders, TRS Projector HL (BHLM), 5100s F/Rear @ 1.75
    Had an issue like this. I swapped the brown and white wires in the harness. This worked for mine.
