Retrofit kit for 2012+!!!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tri2hunt, May 5, 2014.
  1. May 5, 2014 at 11:53 AM
    tri2hunt
    tri2hunt [OP] Well-Known Member
    Micah
    Moscow, Idaho
    2012 DCSB 4x4
    Complete Bi-Xenon FX-R Stage III Retrofit headlight kit from The Retrofit Source with Halos and Butyl. In original box, only opened to verify contents when it arrived. See picture for packing list. Save a little $.
    $280-Shipped lower 48.
  2. May 7, 2014 at 10:31 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    It only fits in the 2012+? I was under the impression the FX-Rs fit into any 2nd gen. Also, I can't seem to see the pictures you have. Which shroud did you get with it?
  3. May 8, 2014 at 11:09 AM
    tri2hunt
    Micah
    Moscow, Idaho
    2012 DCSB 4x4
    Thanks for the question. yes they will fit other years, but I bought it for my 2012 and know that is what the wiring harness will fit. I do not see in my post or title the word only. I did indicate 2012+ since I know the kit will work for those year models.
    Not sure why the pictures are so small, but they are the Apollo shrouds.
    Thanks for looking.
  4. May 8, 2014 at 11:22 AM
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    Oh ok. The way it was typed just looked like you meant 2012 and up. You may have accidentally picked the thumbnail and attached it instead which would account for the small pictures.
