Retrofit or Aftermarket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Warcat, Sep 5, 2020.
  1. Sep 5, 2020 at 9:45 PM
    Warcat
    Warcat [OP] Member
    Jose
    2021 Toyota Tacoma TRD Sport 4WD
    I have a 2015 Tacoma and I want to have Apple CarPlay.... the thing is I’ve been thinking can I retrofit a stock head unit from a 2020 on it so it can be all “stock” or is better to go aftermarket? If I go aftermarket... can I still use my steering wheel controls and my microphone without running a new one? And what about the USB port? Can I still use the original one? Thanks in advance
  2. Sep 5, 2020 at 9:50 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    I have a 2012 and recently installed a Kenwood with a Metra adapter. The adaptor allows me to retain the steering wheel controls, the USB port as well has hooks up to the OBDII so I can have trans temp, etc gauges. Worth it!
    I needed a new mic, but was able to install the new one in the same location as the original. Works just fine.
  3. Sep 6, 2020 at 7:53 AM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    I added a Sony headunit to my 2015 for this reason and really like it. I’d suggest going to the Crutchfield website and it’ll walk you through what you need. I have a bunch of steering wheel controls, back-up cam in reverse and more working.
    Warcat[OP] likes this.
  4. Sep 6, 2020 at 3:01 PM
    Warcat
    Warcat [OP] Member
    Jose
    so the head unit you’ve got behaves like stock radio then? Using the stock USB port and the stock mic right?
  5. Sep 6, 2020 at 6:02 PM
    memtaco
    Stephen
    my truck didn’t have a mic that i know of, so I wired one in. The volume and track buttons work, as does the OEM USB port. Their website will walk you through it all.
    Warcat[QUOTED][OP] likes this.
