Retrofit: Price vs. Functionality
Discussion in 'Lighting' started by CascoYota, Apr 8, 2012.
  1. Apr 8, 2012 at 11:37 AM
    CascoYota
    CascoYota [OP] Well-Known Member
    Casco,ME
    07 Access Cab V6 SR5
    For the past week, I have been reading a lot on retrofitting. I've decided I want to make an attempt at it. From the reviews I have read, theretrofitsource.com is the place to order from.
    I don't want to risk mangling my OEM headlights. So I ordered a set off Ebay for about $117. They were from JDM. Already blacked out.
    My question is this: (Sorry if it has been asked before) What is the best kit to go with? If i'm going to invest the time and money, I would like the finished result to be worth it. However, is their only certain applications where the top kits are worth it?
    For example, I do plan on adding extra lighting. Such as a light bar behind my satoshi.
    I'm stuck between the FX R Stage III and IV kit. If anyone has used either, or better yet, both. I would really like to hear your input on pros and cons to each.
    Thanks in advance!
  2. Apr 8, 2012 at 11:51 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I just ordered a set of the stage IV FX-R's in the group buy and did so because I wanted more light output. That;s why I wanted to retrofit in the first place and it didn't make sense to me to get the stage III just because it's such an easier install. Yes they are plug and play essentially but again, I wanted more light, and in my mind it didn't make sense to sacrifice function for convenience. Just my .02 If you aren't afraid of a dremel or a hole saw, and you truly want to get the most light output possible with your headlights, I 'd say go with the stage IV. As far as your aftermarket lights you ordered are concerned a lot of people have a lot of problems with them fogging up easily since they don't seal as well as the stock housings. In my opinion you should send them back and just go for broke on your stock housings, the bhlm isn't too complicated and I think over all you'll be happier you stayed with the stock ones.
  3. Apr 8, 2012 at 11:52 AM
    benbacher
    Anchorage, AK
    PS you should get in on the group buy we've got going right now. It's about to be closed but I bet if you ordered tomorrow you'd get the 25% discount.
  4. Apr 8, 2012 at 12:00 PM
    CascoYota
    Casco,ME
    Yea, you're right. I guess I will go for those. Well, I was planning on re-sealing the aftermarket lights when I put them back together anyways. Buy the 3M strip sealant. And then use some silicone for the outside of the housing. Just on the off-chance I really screw up. Maybe i'll use the ebay ones as back-ups then and to the retrofit on my stock assemblies. Thanks for the input!
  5. Apr 8, 2012 at 12:00 PM
    CascoYota
    Casco,ME
    Seriously? I'm gonna go check that out right now. Thanks man!
  6. Apr 8, 2012 at 12:11 PM
    benbacher
    Anchorage, AK
    Yup! I saved a hundred bucks off my stage IV kit. MY head works in strange ways. i.e. the more I spend the more I save. My wife feels differently about this logic.
