retrofit question
Discussion in 'Lighting' started by pudge151, May 15, 2011.
  1. May 15, 2011 at 6:45 AM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    are there any HID projector kits out there that accept an H4 HID buld? i have a kit in my stock housing but would consider a retrofit if i could use my current bulbs and ballasts
  2. May 15, 2011 at 7:10 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    A real projector will not accept a standard bulb... The bulbs have a base that is built just right to fit in the projector. You can buy conversion kits so that you can use your current ballasts, but not the bulbs. If you're serious about doing a retrofit what's another $150 for new bulbs and OEM quality ballasts to do the job right?
