retrofit wiring problems!
Discussion in 'Lighting' started by lonzorizo, Aug 4, 2011.
  1. Aug 4, 2011 at 12:02 AM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Been trying to wire my mini d2s up to my 03 tacoma for hours now...more like 4 hours and 47 mins. Its a bi-xenon h4 and I'm using the h4 harness included from TRS. Got everything connected, the three prong input socket thingy was connected like so: black wire prong to tacoma red/green wire prong, red wire prong to tacoma red/yellow wire prong, and blue wire prong to tacoma red/blue wire prong. Fired her up and got high beams, no low beams. Turned my truck off and then switched the red prong with the blue prong on the wire harness thinking this would fix the problem. When I started my truck I had high beams again, and when I went to switch my lever to the high beams position the lights shut off...blew a headlight fuse. Re-enacted scenario on other oem prong input on the right side. Same thing happened. So now I'm out of 10a fuses and clueless as to what I'm doing wrong. I will probably be refreshing this page the rest of the night in hopes of solving my prob. So please help so I can get some rest lol seriously tho.
  2. Aug 4, 2011 at 9:32 AM
    MupxMup
    MupxMup Well-Known Member
    Bay Area, Ca
    11 MGM DC SB 4x4 TRD Sport
    I suggest you contact TRS and ask if the wiring is correct.
    I had the same problem with my TRS BI-XENON: 9003/H4/HB2 relay harness
    The instruction sheet they gave me was wrong and only high beam was working, so I had to switch it up and it worked.
  3. Dec 24, 2011 at 10:03 AM
    SpringSlinger
    SpringSlinger New Member
    Connecticut
    2011 PreRunner
    @ mupxmup
    I just installed the same kit, plugged everything in as it was shipped to me from TRS, and just had high beams. When you say you "switched it up" what wires did you switch?
  4. Dec 25, 2011 at 3:42 PM
    MupxMup
    Bay Area, Ca
    The wires u suppose to connect to the lights, connect it to the ballast. The wires that u're suppose to connect to the ballast, connect them to the lights.
  5. Dec 25, 2011 at 4:03 PM
    dantastic
    dantastic Well-Known Member
    818<->626
    2012 DCLB 4x4 BLK
    I had the exact same problem. The diagram on the TRS website IS WRONG. The plugs for the ballast and bi-xenon solenoids are switched around. Took me 30min and 2 fuses to figure it out :mad:
  6. Dec 25, 2011 at 11:00 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Took me like 4 nights and 5 fuses to figure it out lol.
  7. Dec 26, 2011 at 7:38 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
  8. Dec 26, 2011 at 2:19 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    had the same problem yesterday, took 5 minutes searching hid planet forum and zero fuses
  9. Dec 26, 2011 at 2:50 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The instructions on the TRS website has the plug in connections mixed up. I turned on my lights and I could hear the solenoids. Switched the plugs and then I had lights.
