Retrofit write up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pewpew9787, Dec 25, 2017.
  1. Dec 25, 2017 at 12:50 PM
    Pewpew9787
    Pewpew9787 [OP] Member
    Derreck
    SoCal
    2014 Silver Toyota Tacoma
    MId-travel Icon Total Chaos Retrofit
    I need some tags of some decent write-ups of a complete start to finish of the retrofit install. I don't do crap work so I would like to see some real attention to detail etc. This is my first time doing it so I'm doing a lot of research and plan to start first thing in the morning.
  2. Dec 25, 2017 at 12:55 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    did you try searching? they're pretty easy to find.
  3. Dec 25, 2017 at 1:00 PM
    Pewpew9787
    Derreck
    SoCal
    I'm new to this site.
  4. Dec 25, 2017 at 4:54 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Google "Tacoma world retrofit how to" or "tacoma world DIY retrofit" and you will get plenty of results. I didn't do a write up myself but have made multiple posts covering tricky things I encountered during my install.
    I'm a perfectionist when it comes to working on my stuff, so I researched about a week straight, collected all the info I needed, and started the process. First time I've done a retrofit and I was very pleased with the result. Only thing that isn't covered in depth is the wiring.
    Pewpew9787[OP] likes this.
  5. Dec 25, 2017 at 5:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I learned pretty quick that it's better to just Google the topic with "tacomaworld" in it. It seems to work much better than the search function on this site.. also welcome!
    doorsidedown likes this.
  6. Dec 25, 2017 at 5:03 PM
    Pewpew9787
    Derreck
    SoCal
    thanks b-r-o!!
    magneticwhite88 likes this.
  7. Dec 25, 2017 at 5:06 PM
    Pewpew9787
    Derreck
    SoCal
    THe wiring is my downfall. I want everything looking uniform and professional. I'm sure once its done ill think "it wasn't that bad"!
  8. Dec 25, 2017 at 6:49 PM
    magneticwhite88
    Brandon
    OC, CA
    Just an fyi if you get switchbacks, wire the orange wire for the signal to your tail light blinker and I wired the white wire to an independent switch so I can turn them on and off as I please. That was the only way to avoid hyper flash.
    I would wait to lay out the wiring harness once you wire everything in and you know it works, then you can tidy it all up to make it look OEM!
    By no means am I a electrical wiz, but I was able to get the job done.
